Author Topic: C3D2013 UCS Oddity  (Read 670 times)
C3D2013 UCS Oddity
« on: August 07, 2012, 12:10:42 pm »
I can duplicate this at will... If I have C3D maximized, then after startup I resize the drawing window, the Navcube will flip around and show that I am looking at the Bottom instead of Top. Changing back to Top will change the UCS to an Unnamed UCS.
If I shrink the C3D window, exit C3D, start C3D with a startup drawing (STARTUP=0), the NAVCUBE initially displays correctly, but as the windows resize themselves I can watch the NAVCUBE flip around....see this video
It does this with my DWT and with the OOTB DWT's. With, or without, my add-ins loading. Anyone else seeing this?
Re: C3D2013 UCS Oddity
« Reply #1 on: August 21, 2012, 11:24:54 am »
Anyone notice that you can NOT set the viewport type as required by Plan Production tools?
« Reply #2 on: August 21, 2012, 11:33:24 am »
Only works if one turns off PROPERTYPREVIEW
« Reply #3 on: August 29, 2012, 11:09:58 pm »
I stumbled upon the solution to my strange NAVCUBE display. Turns out that when I have a drawing from a previous version, which has a Coordinate System set, the Geogrphic Location properties get a small rotation and a negative Z factor.  (See image) So I know how to fix this in a drawing, now to find out WHY it's happening and see if I can STOP it from doing so in the first place.
« Reply #4 on: August 30, 2012, 05:55:13 am »
what happens if you insert the old file as a block instead of opening it?
« Reply #5 on: August 30, 2012, 08:57:16 am »
It inserts fine, just as it should.
« Reply #6 on: September 07, 2012, 07:23:01 am »
so it would appear that inserting as a block solves the problem
« Reply #7 on: September 07, 2012, 07:52:35 am »
Well, yes, as long as I don't want to use any of the layouts in the drawing. Or don't mind relabeling drawings which I've inserted that drawing as an xref, or.... So, no, I don't consider it a solution. It's one way to work around an issue that should be corrected.
« Reply #8 on: September 07, 2012, 07:57:15 am »
One can always grab the layouts using Design Center, and 'saving as' resolves the XREF issue
although I agree it is an issue that should be resolved, however as long as the subscription program continues, I don't see it hapening anytime soon. They are too busy getting the next version not ready to ship out the door.
