Hello,
Using Power InRoads V8i: Corridor surface and feature lines appear shifted from alignment location. Shift amount and exact placement seems to be effected by using the View Rotate command. Suspicious it has something to do with Default Origin setting but can not get options to correct the "shift." Point control is not being used and corridor template is set to 0,0 origin. Any thoughts on what may be causing this?
