(setvar "*REVCLOUDMAXARCLENGTH" 1000.0)
Then you might be in luck. Try something like this:Code: [Select](setvar "*REVCLOUDMAXARCLENGTH" 1000.0)If it doesn't error / return nil, check if the registry value has been updated.
(setvar "*REVCLOUDMINARCLENGTH" 1000.0)
(SETVAR "REVCLOUDCREATEMODE" 1) ;_ Force to be Rectangular Cloud, 2 is Polygon cloud. Not sure about others
(SETVAR "REVCLOUDGRIPS" 1) ;_ Force this variable
