Author Topic: Vertexes of a 3D Polyline in a table in Autocad  (Read 3817 times)
teslaxx
« on: July 19, 2012, 02:31:06 AM »
I want to extract the coordinates of Vertexes of a 3D Polyline in a table in Autocad.
I'm a hurry and I'm sure this little app exists but I don't really have the time to make this app.
I don't care if is it in Lisp or .NET.
Re: Vertexes of a 3D Polyline in a table in Autocad
« Reply #1 on: July 19, 2012, 02:57:30 AM »
Would you like fries with that ??
teslaxx
« Reply #2 on: July 19, 2012, 03:12:32 AM »
No.   :-) I'm doing it right now. :D
Question: there is something that already exist in Autocad which does this thing? :)
fixo
« Reply #3 on: July 19, 2012, 08:39:52 AM »
See if this helps
http://www.acadnetwork.com/topic-150.0.html
        [CommandMethod("CreateCoordinateTable","cct", CommandFlags.Modal | CommandFlags.UsePickSet)]
        public void CreateMyTable()
            // based on code written by Kean Walmsley
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            List<double[]> verts = new List<double[]>();
            TypedValue[] values = new TypedValue[]
                        new TypedValue(0, "POLYLINE")
            SelectionFilter filter = new SelectionFilter(values);
            PromptSelectionOptions opts = new PromptSelectionOptions();
            opts.MessageForRemoval = "\nMust be a type of 3dpoly!";
            opts.MessageForAdding = "\nSelect the single 3dpoly: ";
            opts.SingleOnly = true;
            opts.SinglePickInSpace = true;
            opts.AllowDuplicates = false;
            try
                PromptSelectionResult result = ed.GetSelection(opts, filter);
                if (result.Status != PromptStatus.OK) return;
                ed.WriteMessage("\nSelected: {0}\n", result.Value[0].GetType().Name);
                SelectedObject obj = result.Value[0];
                    DBObject dbo = tr.GetObject(obj.ObjectId, OpenMode.ForRead,false) as DBObject;
                    Polyline3d poly = dbo as Polyline3d;
                    if (poly == null)
                        ed.WriteMessage("\nNo 3dPoly");
                        return;
                    foreach (ObjectId vId in poly)
                        PolylineVertex3d v3d = (PolylineVertex3d)tr.GetObject(vId, OpenMode.ForRead);
                        Point3d pt = v3d.Position;
                        verts.Add(new double[] { pt.X, pt.Y, pt.Z });
                    BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                    Table tbl = new Table();
                    tbl.TableStyle = db.Tablestyle;
                    tbl.Position = ed.GetPoint("\nPick a table position: ").Value;
                    TableStyle ts = (TableStyle)tr.GetObject(tbl.TableStyle, OpenMode.ForRead);
                    double textht = ts.TextHeight(RowType.DataRow);
                    int rows = verts.Count;
                    int columns = verts[0].Length;
                    //insert rows
                    tbl.InsertRows(1, textht * 2, rows);
                    // insert columns
                    tbl.InsertColumns(1, textht * 15, columns-1);// first column is already exist, thus we'll have 3 columns
                    //create range to merge the cells in the first row
                    CellRange range = CellRange.Create(tbl, 0, 0, 0, columns-1);
                    tbl.MergeCells(range);
                    // set style for title row
                    tbl.Cells[0, 0].Style = "Title";
                    tbl.Cells[0, 0].TextString = "Coordinate Table";
                    tbl.Rows[0].Height = textht * 2;
                    tbl.InsertRows(1, textht * 2, 1);
                    // set style for header row
                    tbl.Rows[1].Style = "Header";
                    tbl.Rows[1].Height = textht * 1.5;
                    string[] headers = { "X", "Y", "Z" };
                    //create contents in the first cell and set textstring
                    tbl.Cells[1, 0].Contents.Add();
                    tbl.Cells[1, 0].Contents[0].TextString = headers[0];
                    for (int c = 1; c < columns; c++)
                        //for all of the rest cells just set textstring (or value)
                        tbl.Cells[1, c].TextString = headers[c];
                    for (int r = 2; r < rows + 2; r++)//exact number of data rows + title row + header row
                        // set style for data row
                        tbl.Rows[r].Style = "Data";
                        tbl.Rows[r].Height = textht * 1.25;
                   // set column widths
                    foreach (Column col in tbl.Columns)
                        col.Width = textht * 15;
                    //change last column values just to show data formatting
                    // to set numeric values with precision of 3 decimals:
                    // create DataTypeParameter object
                    // set data type,set value, then data format for every cell:
                    DataTypeParameter dtp = new DataTypeParameter();
                    dtp.DataType = DataType.Double;
                    dtp.UnitType = UnitType.Unitless;  // or  UnitType.Unitless
                    //populate column with  values:
                    int ct = 0;
                        for (int c = 0; c < columns; c++)
                            tbl.Cells[r, c].Contents.Add();
                            tbl.Cells[r, c].Contents[0].DataFormat = "%lu2%pr3%th44";//or "%lu2%pr3%"
                            tbl.Cells[r, c].Contents[0].DataType = dtp;
                            tbl.Cells[r, c].Contents[0].SetValue(verts[ct][c], ParseOption.ParseOptionNone);
                        ct += 1;
                    tbl.GenerateLayout();
                    btr.AppendEntity(tbl);
                    tr.AddNewlyCreatedDBObject(tbl, true);
                    tr.Commit();
            catch (System.Exception ex)
                ed.WriteMessage(ex.Message + "\n" + ex.StackTrace);
~'J'~
« Last Edit: July 19, 2012, 04:25:24 PM by fixo »
fixo
« Reply #4 on: August 01, 2012, 02:01:34 AM »
I'm wondering is something wrong with my code...
~'J'~
