Author Topic: AU 2012 class worth visiting  (Read 6434 times)
« on: July 16, 2012, 04:59:20 AM »
from http://through-the-interface.typepad.com/through_the_interface/2012/07/thinking-about-au-2012-and-vacation.html#comments
 Scott McFarlane said...
< .. >  The two classes I will be teaching, which your readers may be interested in are:
CP2654 - Automated Testing with the AutoCAD .NET API
CP2657 - Programming AutoCAD with C#: Best Practices
- Scott
They are probably worth spending 20 hours each way in a plane seat to hear !
Wish we could get an early draft :)
Draftek
Re: AU 2012 class worth visiting
« Reply #1 on: July 16, 2012, 08:30:52 AM »
I attended the Best Practices class last year. Autodesk made an effort to include more of these types of classes and it was the best AU (for a developer) I've ever attended.
I've been to 11
Arizona
« Reply #2 on: August 28, 2012, 02:31:28 PM »
I signed up for both of these. Thanks for the recommendation!
« Reply #3 on: August 28, 2012, 02:36:32 PM »
I'm envious Lori.
Can I copy your homework ? :-D
Hope you enjoy him.
Arizona
« Reply #4 on: August 28, 2012, 02:40:06 PM »
Of course you can!
And for you Kerry, I will share.
« Reply #5 on: August 28, 2012, 04:31:18 PM »
I'm signed up for the c# class, only have to wait ~3 months now.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #6 on: August 28, 2012, 08:09:09 PM »
Cheese and Rice! I do a few ~13hr flights a year...  a 20hr flight would just be unbearable. I'd need Xanax and PinkFloyd on loop through noise reduction headphones.  :-D
Jeff H
« Reply #7 on: August 28, 2012, 08:15:20 PM »
Cheese and Rice! I do a few ~13hr flights a year...  a 20hr flight would just be unbearable. I'd need Xanax and PinkFloyd on loop through noise reduction headphones.  ;D
Get 3mg a day
MexicanCustard
« Reply #8 on: August 29, 2012, 07:53:08 AM »
me too  :-)
« Reply #9 on: August 29, 2012, 08:02:30 AM »
Let's hope Scott's classes are as good as I expect  :)
Arizona
« Reply #10 on: August 29, 2012, 08:24:31 AM »
... PinkFloyd on loop through noise reduction headphones.  :-D
That would be my choice also!
I tried to register for the C# Tips and Tricks class but it was already full. And this was the first day of registration?
SGP2012
« Reply #11 on: August 29, 2012, 07:49:47 PM »
The AU team reserve some slots to schedule repeats of popular classes, so keep checking the website.
MexicanCustard
« Reply #12 on: August 30, 2012, 12:49:36 PM »
Last year I signed up on day three and missed a class I wanted.  At the time of the class I asked if I could sit in and they asked me to wait to see if there would be room when the class started. As soon as the class started there were a couple of empty chairs and they let me in.  So if all else fails you may still get in if there is sitting room.
Arizona
« Reply #13 on: August 30, 2012, 12:52:17 PM »
Thank you both! I will keep checking back.
« Reply #14 on: September 07, 2012, 06:44:02 PM »
I hope the notes and samples for this are complete
https://www.autodeskuniversity2012.com/connect/sessionDetail.ww?SESSION_ID=2654&tclass=popup
'cause it's information that is difficult to glean in isolation.
CP2654 - Automated Testing with the AutoCAD® .NET API
Scott McFarlane , Woolpert, Inc.
Automated testing, which includes unit testing and integration testing, is one of the cornerstones of the Agile development process. Yet we see it as difficult and expensive, especially for programs written with the AutoCAD .NET API. So what makes it so difficult? What are the obstacles? Can we overcome them? This class will explore the topic of automated testing, specifically for .NET programs written for products based on AutoCAD software. You will learn how good programming practices, such as single responsibility, abstraction, interface development, and dependency inversion, go hand in hand with writing testable code, and how to use these techniques to decouple your code from the AutoCAD API, enabling you to unit test your business logic in Microsoft® Visual Studio®. We’ll also look at a few of the popular testing tools, including the Gallio Automation Platform, which integrates AutoCAD into its test runner.
