Author Topic: Attach Drawing in Map 3D  (Read 1881 times)
Muzza51
« on: July 15, 2012, 05:11:51 PM »
I am getting a "Reference to a non-shared member requires an object reference" error with the following code which is straight out of the developers guide:
The offending code is:
Public Sub AttachDrawing()
        Dim aliasList As Aliases
        aliasList = Autodesk.Gis.Map.MapApplication.Aliases  'This is the line generating the error.
Any assistance in identifying where I am going wrong would be appreciated.
n.yuan
Re: Attach Drawing in Map 3D
« Reply #1 on: July 16, 2012, 09:49:44 AM »
Are you using VS to write code? if yes, did you notice that after you enter "." following MapApplication, there is no interllisense prompt for you to choose a property called "Aliases"?
You should use HostMapApplicationServices' Application property (which is an instance of MapApplication) to reach Aliases:
Dim aliaseList As Aliases = Autodesk.Gis.Map.HostMapApplicationServices.Application.Aliases
HTH
Muzza51
« Reply #2 on: July 16, 2012, 05:47:16 PM »
Many thanks, that fixed it. That will teach me to cut and paste instead of typing it in. :-)
