Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Adding Datum and Coordinate code to title block
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Adding Datum and Coordinate code to title block (Read 1516 times)
everblader
Guest
on:
July 13, 2012, 02:58:46 PM »
Is there a way to display the projection (FL-W83) or Datum (NAD83) of a DWG file (Civil3D) in the titleblock? I am not very good at programming and was wondering if anyone had done this.
EB
Logged
jvillarreal
Bull Frog
Re: Adding Datum and Coordinate code to title block
Reply #1 on:
July 13, 2012, 03:54:13 PM »
What would you want the code to do exactly?
If you're wanting to have a routine place the text for you in each drawing, it's possible..
You can get the projection with this function:
Code:
[Select]
(ade_projgetwscode)
Logged
King Gator
C3D user & customizer
Reply #2 on:
July 13, 2012, 04:08:08 PM »
What is the name of the Title block and which attributes (Tag names) do you want the data input to? I showed you how to get the required data on the Autodesk C3D forum, you never mentioned that you didn't know how to do the rest of the code.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
