Author Topic: SSGET + custom message + keywords  (Read 6550 times)
vladimirzm
« on: July 12, 2012, 09:38:38 PM »
hi,
I am looking a way to do this with ssget:
Select objects to add or [option1/option2]: <option1>
will it be possible?
just with autolisp visuallisp
the search doesn't give me any answer.
irneb
Re: SSGET + custom message + keywords
« Reply #1 on: July 13, 2012, 02:05:16 AM »
Unfortunately ssget is one of the input functions which don't allow a custom message. Neither does it adhere to initget.
There's 3 work-arounds (in order of my preference - best to worst):
  • Have ssget return nil if nothing selected (i.e. Space or Enter pressed), then start a getkword for options and return to ssget again.
  • Do the options before ssget ... similar to what happens in the Offset command.
  • Ask for getpoint + getcorner for window/crossing selection, or a series of getpoints for fence/WPoly/CPoly, or a series of entsel's, etc. Then pass these as a selection point list to ssget.
It's not pretty, but I don't know of any other way.
« Reply #2 on: July 13, 2012, 02:55:25 AM »
I'd be writing a helper function that combines the prompts and selection and addition to a selection set.
Just my 2 cents.
Regards
kdub
irneb
« Reply #3 on: July 13, 2012, 04:17:16 AM »
Do you mean a defun to do the getpoints and ssget (as per my option 3)? Or do you mean create a new ssget-extended in DotNet / ARX?
« Reply #4 on: July 13, 2012, 04:32:32 AM »
Yes.
But it would depend on the OP's actual requirement.
I use several variants to achieve what I want personally ( collected in my library).
I prefer a routine that is explicit in it's purpose .... so it can be thoroughly tested.
« Reply #5 on: July 13, 2012, 08:09:17 AM »
This old function could be expanded to accommodate custom keywords:
http://www.theswamp.org/index.php?topic=34804
For a custom selection message, I use this:
  1. ;; ssget  -  Lee Mac
  2. ;; A wrapper for the ssget function to permit the use of a custom selection prompt
  3. ;;
  4. ;; Arguments:
  5. ;; msg    - selection prompt
  6. ;; params - list of ssget arguments
  7.
  8. (defun LM:ssget ( msg params / sel )
  9.     (princ msg)
  10.     (setvar 'nomutt 1)
  11.     (setq sel (vl-catch-all-apply 'ssget params))
  12.     (setvar 'nomutt 0)
  13.     (if (and sel (not (vl-catch-all-error-p sel)))
  14.         sel
  15.     )
  16. )
irneb
« Reply #6 on: July 13, 2012, 11:19:32 AM »
Slight mod  ;)
  3. ;;
  4. ;; Arguments:
  7.
  9.     (princ msg)
  13.     (if (not (vl-catch-all-error-p sel))
  14.         sel
  15.     )
  16. )
If the sel variable = nil, then return it anyway. Doesn't make any difference.
Unfortunately it still doesn't allow for keywords as other get* functions do: http://docs.autodesk.com/ACD/2011/ENU/filesALR/WS1a9193826455f5ff1a32d8d10ebc6b7ccc-69da.htm
Which is what I understood from the OP's request. At least with your defun the message is displayed as if it's a custom message for ssget.
vladimirzm
« Reply #7 on: July 13, 2012, 01:19:52 PM »
thank you everybody, and Lee Mac for LM:ssget
so far I'm using ENTER for nothing selected, other ways are too long for a small routine
I have been searching how autocad handles this, and i get surprise of GROUP command.
I need that power...  :x
« Reply #8 on: July 13, 2012, 02:51:08 PM »
Slight mod  ;)
I know - hence the first suggestion in my post, however the function I linked to would still require rather a lot of modification.  :|
VovKa
  • Ukraine
« Reply #9 on: July 14, 2012, 01:53:46 PM »
http://www.theswamp.org/index.php?topic=19881.msg246261#msg246261
SelAtts can be modified to work not only with attributes but with any entity type
