Author Topic: The online AutoCAD 2013 .NET Developers Guide  (Read 8270 times)
flowerrobot
Re: The online AutoCAD 2013 .NET Developers Guide
« Reply #1 on: July 12, 2012, 06:42:23 PM »
And here I was using the 2010 one.
Thank you
josephlopez
« Reply #2 on: July 17, 2012, 07:33:36 AM »
I was in search for this since a long time thanks for sharing mate. lol.
PATMANG
« Reply #3 on: July 17, 2012, 02:15:33 PM »
Thanks for the info.!
flowerrobot
« Reply #4 on: July 22, 2012, 07:35:47 PM »
« Reply #5 on: July 22, 2012, 09:19:45 PM »
I think I like the 2010 version better, Layout is nicer.
http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%20.NET%20Developer's%20Guide/index.html
Perhaps, but it's not for 2013  :)
or 2011 or 2012 ...
CADbloke
  • Crash Test Dummy
« Reply #6 on: April 24, 2013, 07:16:49 PM »
Here's the 2014 guide: http://docs.autodesk.com/ACD/2014/ENU/
Don't bother - it is the same abomination that the 2013 guide is, proving once again that Autodesk is a magnificent case study in how to stuff up a website.
At least they provide a .chm file in the SDK that you can use and search in. Autodesk, please don't break that too.
TheMaster
« Reply #7 on: April 24, 2013, 11:10:58 PM »
   "Search is your entry point to Help."
For Autodesk, it seems that search, and the distinct lack of reasonable navigation (e.g., outline/table of contents) is not an entry point, it is a deliberate barrier, rather than a product of deficient or bad decision making.  That idea is based largely on the theory that Autodesk is very deliberately targeting new users of AutoCAD, as part of a systematic effort to discourage them from learning and becoming comfortable with using it, as that makes it much more difficult to coerce them to abandon it and switch to another Autodesk 'replacement' product.
Unfortunately, that tactic has a major downside for more than just noobs.
If you haven't noticed, the online help for non-AutoCAD products and AutoCAD verticals seems to conform to a completely different and higher set of standards.
Of course, a tactic like that lends itself to the widespread perception and belief that plain 'vanilla' AutoCAD users are, in the eyes of Autodesk, second-class citizens, in spite of the fact that they are responsible for the lion's share of their revenues.
« Last Edit: April 25, 2013, 01:36:16 AM by TT »
huiz
  • Certified Prof C3D
« Reply #8 on: April 25, 2013, 04:30:49 AM »
