Author Topic: Rotate selection before move or copy  (Read 1663 times)
Woabow
« on: July 11, 2012, 10:55:09 AM »
One thing that I really miss in Acad is the possibility to rotate a selection while moving around during a Move or Copy command. During the Insert command there is the Rotate sub-command, but when moving or copying objects there is no way to rotate before placing the selection.
Rotating the object after placing it is no option in my situation, I need to see the rotated objects before I can see where to place them.
I found this topic http://www.theswamp.org/index.php?topic=40686.0 but it does not work with Move and Copy and has no osnap by default.
Does anybody know how to do this?
irneb
Re: Rotate selection before move or copy
« Reply #1 on: July 11, 2012, 11:22:49 AM »
Try the Express tool MoCoRo ... it combines Move Copy & Rotate into one command. As per my post #10 in that thread.
Woabow
« Reply #2 on: July 11, 2012, 11:40:07 AM »
For me MOCORO is the same as doing a separate Move and Rotate.
It's not about "is it possible", it's about "how fast is it".
Or is it possible to define a function key that rotates the selection 45 degrees without placing the objects first?
Hugo
« Reply #3 on: July 11, 2012, 01:55:12 PM »
Something I am also looking for a long time
Sowas suche ich auch schon lange
