Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Rotate selection before move or copy
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Rotate selection before move or copy (Read 1667 times)
Woabow
Newt
on:
July 11, 2012, 10:55:09 AM »
One thing that I really miss in Acad is the possibility to rotate a selection while moving around during a Move or Copy command. During the Insert command there is the Rotate sub-command, but when moving or copying objects there is no way to rotate before placing the selection.
Rotating the object after placing it is no option in my situation, I need to see the rotated objects before I can see where to place them.
I found this topic
http://www.theswamp.org/index.php?topic=40686.0
but it does not work with Move and Copy and has no osnap by default.
Does anybody know how to do this?
Logged
irneb
Water Moccasin
ACad R9-2016, Revit Arch 6-2016
WWW
Re: Rotate selection before move or copy
Reply #1 on:
July 11, 2012, 11:22:49 AM »
Try the Express tool MoCoRo ... it combines Move Copy & Rotate into one command. As per my post #10 in that thread.
Logged
Woabow
Newt
Reply #2 on:
July 11, 2012, 11:40:07 AM »
For me MOCORO is the same as doing a separate Move and Rotate.
It's not about "is it possible", it's about "how fast is it".
Or is it possible to define a function key that rotates the selection 45 degrees without placing the objects first?
Logged
Hugo
Bull Frog
Reply #3 on:
July 11, 2012, 01:55:12 PM »
Something I am also looking for a long time
Sowas suche ich auch schon lange
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
