Author Topic: Revit Ceiling height will not blank out  (Read 7038 times)
Krushert
  • FREE BEER Tomorrow!!
Re: Revit Ceiling height will not blank out
« Reply #15 on: July 11, 2012, 02:02:47 PM »
Okay I understand the room voluming part by using the limits thing.  And I knew it had to be turned on.  We will eventually do the calcs but for know I will leave that off.
What I think the person did was that they created this ceiling parameter for Room Finish Schedule to indicate where a particular ceiling finish like Acoustical Ceiling Tile is in height
Now here is another question for the real world application.   With something porous as a Ceiling grid, is that the limit of the room for  the voluming calcs or does voluming calcs has to consider the space above the Ceiling Grid?
So that
« Last Edit: July 11, 2012, 03:56:40 PM by Krushert »
I no longer CAD or Model, I just hang out here for camaraderie
Krushert
« Reply #16 on: July 11, 2012, 03:58:24 PM »
But that still does not help me clear my project parameter so it will correctly show in Finish Schedule.
This afternoon has gotten crazy, sorry for the terse response.
Matt__W
  • I like my water diluted.
« Reply #17 on: July 11, 2012, 04:11:29 PM »
When you place a ROOM object, the CEILING HEIGHT parameter is blank by default.  As soon as you enter a value, all bets are off.  There's no going back to a NULL value.  It expects a dimension.  You could set it to 0'-0" and have a note about 0-height ceilings or, as a last resort, delete the room objects and replace them.  Of course, by doing this, you also lose any information that you previously entered.  I.E. room name, number, finish types, upper/lower limits, etc...
Autodesk Expert Elite
