enter a value or formula starting with '='
I tried 0'-0" but that shows in the schedule. I want the schedule to be blank. It will read blank if I do not input anything at all like I have for other rooms with exposed structure. Worse case I will delete the room and start over.
Quote from: Krushert on July 11, 2012, 08:52:49 AMI tried 0'-0" but that shows in the schedule. I want the schedule to be blank. It will read blank if I do not input anything at all like I have for other rooms with exposed structure. Worse case I will delete the room and start over. If you have an exposed structure, WHY are you adding a ceiling??
Okay I learning Revit on the fly and I inadvertently put a value in the ceiling height parameter for a room.
architects are dumb
Quote from: Matt W on July 11, 2012, 09:03:32 AMQuote from: Krushert on July 11, 2012, 08:52:49 AMI tried 0'-0" but that shows in the schedule. I want the schedule to be blank. It will read blank if I do not input anything at all like I have for other rooms with exposed structure. Worse case I will delete the room and start over. If you have an exposed structure, WHY are you adding a ceiling??From my OP with large bold print for blind MEPsQuote from: Krushert on July 11, 2012, 08:21:55 AMOkay I learning Revit on the fly and I inadvertently put a value in the ceiling height parameter for a room. Quote from: Matt W on July 11, 2012, 09:03:32 AMarchitects are dumbNo argument there.
and from what I can tell, he's saying that the ROOM OBJECT has a ceiling height parameter that accidentally got filled in...
If you have an exposed structure, you don't have a ceiling. Delete it.
ROOMs have a LIMIT OFFSET that you can use to get the volume of the room regardless of whether or not there's a ceiling placed. But the LIMIT OFFSET must be greater than 0.
what version are you using?
do you want the room height to go up to structure?
this is for calcs, right?
Yes it is there. And when I click the modify button, I see that its group parameter is "other" and under Categories the "Rooms" is checked.
