Author Topic: Draw a Polyine3d, assign an Xrecond, return the objectId. But nothing on screen!  (Read 3187 times)
waterharbin
Hi.
I want to draw a rectangle to represent a room. I use a PolyLine3d to do this. And I want to add a Xrecord to this rectangle. I define a function which will return the ObjectId. So sometime later, I will need to obtain the Xrecord through the ObjectId. Here are the codes I collected form some books. They can be compiled, but when I run the command, I get nothing on the screen. Where is the problem?
    Public Shared Function AppendEntity(ByVal ent As Entity) As ObjectId
        Dim db As Database = HostApplicationServices.WorkingDatabase
        Dim entId As ObjectId
        Using trans As Transaction = db.TransactionManager.StartTransaction
            Dim bt As BlockTable = trans.GetObject(db.BlockTableId, OpenMode.ForRead)
            Dim btr As BlockTableRecord = trans.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
            entId = btr.AppendEntity(ent)
            trans.AddNewlyCreatedDBObject(ent, True)
            trans.Commit()
        End Using
        Return entId
    End Function
   Public Shared Function AddRectangle(ByVal cenPt As Point3d, ByVal Height As Double, _
                                        ByVal Length As Double, ByVal Name As String, ByVal Size As String) As ObjectId
        Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
            Dim Xrec As New Xrecord()
            Xrec.Data = New ResultBuffer( _
                        New TypedValue(DxfCode.Text, Size), _
                        New TypedValue(DxfCode.Text, Name))
            'Define the rectangle
            Dim Pt(4) As Point3d
            Pt(0) = New Point3d(cenPt.X - Length * 0.5, cenPt.Y - Height * 0.5, 0)
            Pt(1) = New Point3d(cenPt.X + Length * 0.5, cenPt.Y - Height * 0.5, 0)
            Pt(2) = New Point3d(cenPt.X + Length * 0.5, cenPt.Y + Height * 0.5, 0)
            Pt(3) = New Point3d(cenPt.X - Length * 0.5, cenPt.Y + Height * 0.5, 0)
            Pt(4) = New Point3d(cenPt.X - Length * 0.5, cenPt.Y - Height * 0.5, 0)
            Dim Pts As New Point3dCollection(Pt)
            Dim ent As New Polyline3d(Poly3dType.SimplePoly, Pts, False)
            'Add the rectangle polyline entity to model space
            Dim EntId As ObjectId = AppendEntity(ent)
            ent.CreateExtensionDictionary()
            EntId = ent.ExtensionDictionary()
            Dim entXrecord As DBDictionary = trans.GetObject(EntId, OpenMode.ForWrite)
            entXrecord.SetAt("MyXrecode", Xrec)
            trans.AddNewlyCreatedDBObject(Xrec, True)
            Return EntId
            trans.Commit()
        End Using
    End Function
    Private RectIds As ObjectIdCollection = New ObjectIdCollection()   'Hold the ObjectId for later use
    <CommandMethod("DrawRectXRecord")> _
    Public Sub InsertRectWithXRecord()
        '' Get the current database and start the Transaction Manager
        Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
        Dim acCurDb As Database = acDoc.Database
        Dim acEd As Editor = acDoc.Editor
        Dim pPtRes As PromptPointResult
        Dim pPtOpts As PromptPointOptions = New PromptPointOptions("")
        pPtOpts.Message = vbLf & "Click to insert "
        pPtRes = acDoc.Editor.GetPoint(pPtOpts)
        Dim ptStart As Point3d = pPtRes.Value
        '' Exit if the user presses ESC or cancels the command
        If pPtRes.Status = PromptStatus.Cancel Then Exit Sub
        '' Start a transaction
        Using Trans As Transaction = acCurDb.TransactionManager.StartTransaction()
            'Draw the Rectangle
            Dim RectId As ObjectId = AddRectangle(ptStart, 1000, 2000, "RectWithXRecord", "1000X2000")
            RectIds.Add(RectId)
            acEd.WriteMessage(vbCrLf + RectId.ToString())   'I can get the ObjectId showed on the command line panel
            Trans.Commit()
        End Using
    End Sub
« Last Edit: July 08, 2012, 03:38:21 AM by 闻仲 »
gile
  • Marseille, France
You did not append the Polyline to model space, furthermore, you'd don't need to start three transaction (one is enough).
Here's a C# snippet:
Code - C#: [Select]
  1.         [CommandMethod("DrawRectXRecord")]
  2.         public void InsertRectWithXRecord()
  3.         {
  4.             // Get the active document editor
  5.             Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
  6.
  7.             PromptPointOptions ppo = new PromptPointOptions("\nClick to insert: ");
  8.             PromptPointResult ppr = ed.GetPoint(ppo);
  9.             // Exit if the user presses ESC or cancels the command
  10.             if (ppr.Status != PromptStatus.OK) return;
  11.
  12.             Point3d ptStart = ppr.Value.TransformBy(ed.CurrentUserCoordinateSystem);
  13.
  14.             ObjectId rectId = AddRectangle(ptStart, 1000.0, 2000.0, "RectWithXRecord", "1000X2000");
  15.
  16.             ed.WriteMessage("\n" + rectId.ToString());
  17.         }
  18.
  19.         private ObjectId AddRectangle(Point3d cenPt, double height, double length, string name, string size)
  20.         {
  21.             // Return value
  22.             ObjectId retVal = ObjectId.Null;
  23.
  24.             // Get the current database and start a transaction
  25.             Database db = HostApplicationServices.WorkingDatabase;
  26.             using (Transaction tr = db.TransactionManager.StartTransaction())
  27.             {
  28.                 // Add the rectangle polyline entity to the current space
  29.                 Point3d[] pts =
  30.                 {
  31.                     new Point3d(cenPt.X - length * 0.5, cenPt.Y - height * 0.5, 0.0),
  32.                     new Point3d(cenPt.X + length * 0.5, cenPt.Y - height * 0.5, 0.0),
  33.                     new Point3d(cenPt.X + length * 0.5, cenPt.Y + height * 0.5, 0.0),
  34.                     new Point3d(cenPt.X - length * 0.5, cenPt.Y + height * 0.5, 0.0)
  35.                 };
  36.                 Polyline3d ent = new Polyline3d(Poly3dType.SimplePoly, new Point3dCollection(pts), true);
  37.                 BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
  38.                 retVal = btr.AppendEntity(ent);
  39.                 tr.AddNewlyCreatedDBObject(ent, true);
  40.
  41.                 // Add the extension dictionary and xrecord to the polyline
  42.                 Xrecord xrec = new Xrecord();
  43.                 xrec.Data = new ResultBuffer(
  44.                     new TypedValue((int)DxfCode.Text, size),
  45.                     new TypedValue((int)DxfCode.Text, name));
  46.                 ent.CreateExtensionDictionary();
  47.                 DBDictionary xDict = (DBDictionary)tr.GetObject(ent.ExtensionDictionary, OpenMode.ForWrite);
  48.                 xDict.SetAt("MyXrecode", xrec);
  49.                 tr.AddNewlyCreatedDBObject(xrec, true);
  50.                 tr.Commit();
  51.             }
  52.             return retVal;
  53.         }
« Last Edit: July 08, 2012, 07:57:26 AM by gile »
waterharbin
Thanks,gile.
But I am a little curious, why I can't append the PolyLine to Model Space. And I was told that transactions can be nested. Dose a transaction cost much? So we need as less as we can.
This is an old project writted in VB. So here are the VB snippet, and the command to get the Xrecords back too.
Maybe someone else may need it in VB too,haha. :-)
        'the objectId will be retured
        Dim retVal As ObjectId = ObjectId.Null()
            ' 在内存中创建一个未经拟合的标准三维多段线对象.
            Dim ent As New Polyline3d(Poly3dType.SimplePoly, Pts, True)
            Dim btr As BlockTableRecord = trans.GetObject(db.CurrentSpaceId, OpenMode.ForWrite)
            '新建一个扩展记录对象
            'Add the extension dictionary and xrecord to the polyline
            Dim xDict As DBDictionary = trans.GetObject(ent.ExtensionDictionary, OpenMode.ForWrite)
            xDict.SetAt("MyXrecods", Xrec)
            trans.Commit()
        End Using
        Return retVal
    End Function
        '绘制矩形
        'Draw the Rectangle
        RectIds.Add(RectId)
    End Sub
    <CommandMethod("ListRectXRecord")> _
    Public Sub ListRectWithXrecord()
            ' 遍历选择集.
            For Each sSetEntId As ObjectId In RectIds
                Dim ent As Entity = trans.GetObject(sSetEntId, OpenMode.ForRead)
                'ed.WriteMessage((vbCrLf & "您选择的是: " & ent.GetType().Name))
                '打开所选择对象的扩展字典
                Dim entXrecord As DBDictionary = trans.GetObject(ent.ExtensionDictionary, OpenMode.ForRead)
                '在扩展字典中搜索关键字为MyXrecord的扩展记录对象,如果找到则返回它的ObjectId
                Dim xrecordId As ObjectId = entXrecord.GetAt("MyXrecods")
                '打开找到的扩展记录对象
                Dim xrecord As Xrecord = trans.GetObject(xrecordId, OpenMode.ForRead)
                '获取扩展记录中包含的数据列表并循环遍历显示它们
                Dim rb As ResultBuffer = xrecord.Data
                For Each value As TypedValue In rb
                    ed.WriteMessage(String.Format(vbCrLf & "TypeCode={0},Value={1}", value.TypeCode, value.Value))
                Next
            Next sSetEntId
            'Dim ent As Entity = trans.GetObject(res.ObjectId, OpenMode.ForRead)
            trans.Commit()
        End Using
    End Sub
« Last Edit: July 08, 2012, 08:55:19 AM by 闻仲 »
