Author Topic: How can i find touching line objects at the end points?  (Read 3577 times)
cincir
« on: July 05, 2012, 06:15:42 PM »
How can i find touching line objects at the end points without iterating through the blocktablerecord's entities?
SGP2012
Re: How can i find touching line objects at the end points?
« Reply #1 on: July 05, 2012, 09:32:55 PM »
Whatever method you use, you'll ultimately be iterating entities - either in your code or behind the scenes. The exception being on screen selection, so you could try using the line start/end points to create a Fence selection. On screen selection uses the graphics cache (instead of iterating the database) to optimize peformance. The disadvantages are that it only works when the geometry is displayed on the screen and accuracy is reduced as you zoom out. If you have to zoom or pan your drawing to use this method, then you're probably better off iterating the database.
Editor.SelectFence().
Cheers,
Stephen
fixo
« Reply #2 on: July 06, 2012, 04:57:42 AM »
You can use PointMonitor event to get start point
with or without picking the lline, here is the code completely borrowed
from Kean Walmsley:
using System;
using System.Linq;
using System.Text;
[assembly: CommandClass(typeof(AutoCAD_CSharp_plug_in1.EndTouch))]
namespace AutoCAD_CSharp_plug_in1
    public class EndTouch
        [CommandMethod("SiM")]
        public static void StartMonitor()
            ed.PointMonitor += new PointMonitorEventHandler(ed_PointMonitor);
        [CommandMethod("XiM")]
        public static void StopMonitor()
            ed.TurnForcedPickOn();
            ed.PointMonitor -= new PointMonitorEventHandler(ed_PointMonitor);
        public static void ed_PointMonitor(object sender, PointMonitorEventArgs e)
            Editor ed = (Editor)sender;
            Document doc = ed.Document;
            double gap = (double)Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("dimtxt");
            try
                FullSubentityPath[] paths = e.Context.GetPickedEntities();
                // Go through the results of the selection
                // and detect the curves
                // string curveInfo = "";
                Transaction tr = doc.TransactionManager.StartTransaction();
                using (tr)
                    // Open each object, one by one
                    foreach (FullSubentityPath path in paths)
                        ObjectId[] ids = path.GetObjectIds();
                        if (ids.Length > 0)
                            ObjectId id = ids[ids.GetUpperBound(0)];
                            DBObject obj = tr.GetObject(id, OpenMode.ForRead);
                            if (obj != null)
                                // If it's a Line, get its start point
                                Line ln = obj as Line;
                                if (ln != null)
                                    double length = ln.GetDistanceAtParameter(ln.EndParam) - ln.GetDistanceAtParameter(ln.StartParam);
                                    // Then get start point of line
                                    Point3d pnt = ln.StartPoint;
                                    ed.DrawVector(new Point3d(pnt.X + gap, pnt.Y + gap, pnt.Z), new Point3d(pnt.X - gap, pnt.Y - gap, pnt.Z), 1, false);
                                    ed.DrawVector(new Point3d(pnt.X + gap, pnt.Y - gap, pnt.Z), new Point3d(pnt.X - gap, pnt.Y + gap, pnt.Z), 1, false);
                    tr.Commit();
            catch
                // Not sure what we might get here, but not real action
                // needed (worth adding an Exception parameter and a
                // breakpoint, in case things need investigating).
~'J'~
cincir
« Reply #3 on: July 06, 2012, 09:43:59 AM »
Thank you fixo but i am thinking of selecting a line then trying to find the other lines those are touching the one that i selected at the end.
fixo
« Reply #4 on: July 06, 2012, 10:05:11 AM »
to create chain selection just iterate through selected lines
then compare the ends / starts of these lines, nothing else
~'J'~
TheMaster
« Reply #5 on: July 06, 2012, 11:47:19 AM »
I'm not sure why you can't iterate over the entities in a BlockTableRecord, but that's really how it needs to be done. So, can I ask why you are imposing that restriction (e.g., 'without iterating through the blocktablerecord's entities' ?
cincir
« Reply #6 on: July 06, 2012, 06:25:42 PM »
Simple because it takes too long  :-)
TheMaster
« Reply #7 on: July 06, 2012, 10:05:27 PM »
If you want to limit the candidate objects/lines to only those
that are visible in the current view, you can use a window or
crossing selection to get them, and then do the search, but
when finding connecting lines, I wouldn't consider visiblity in
the current view as a legitimate constraint.
So, if the only way to do it correctly takes too long, then I guess
you are left with two possible choices: Do it correctly, or don't
do it at all.   :-D
fixo
« Reply #8 on: July 08, 2012, 01:43:35 AM »
Try to adopt this code to your needs
Another way is to create selection set based on screen coordinates
to create it using CrossingWindow mode then iterate through
this selection set instead of looping entitre the whole BlockTableRecord,
just a hint...
        [CommandMethod("testJoinLines","tjl", CommandFlags.Modal | CommandFlags.UsePickSet)]
        public void TestConnectedLines()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            PromptEntityOptions pso = new PromptEntityOptions("\nPick a single line to join: ");
            pso.SetRejectMessage("\nObject must be of type Line!");
            pso.AddAllowedClass(typeof(Line), false);
            PromptEntityResult res = ed.GetEntity(pso);
            if (res.Status != PromptStatus.OK) return;
                BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForRead) as BlockTableRecord;
                List<ObjectId> ids = JoinLines(btr, res.ObjectId);
                ObjectId[] lines = ids.ToArray();
                ed.SetImpliedSelection(lines);
                //or
                //ed.SetImpliedSelection(ids.OfType<ObjectId>().ToArray());
                PromptSelectionResult chres = ed.SelectImplied();
                if (chres.Status != PromptStatus.OK)
                    ed.WriteMessage("\nNothing added in the chain!");
                    return;
                foreach (SelectedObject selobj in chres.Value)
                    Entity subent = tr.GetObject(selobj.ObjectId, OpenMode.ForWrite) as Entity;
                    subent.ColorIndex = 4;
                tr.Commit();
        private void SelectConnectedLines(BlockTableRecord btr, List<ObjectId> ids, ObjectId id)
            Entity en = id.GetObject(OpenMode.ForRead, false) as Entity;
            Line ln = en as Line;
            if (ln != null)
                foreach (ObjectId idx in btr)
                    Entity ex = idx.GetObject(OpenMode.ForRead, false) as Entity;
                    Line lx = ex as Line;
                    if (((ln.StartPoint == lx.StartPoint) || (ln.StartPoint == lx.EndPoint)) ||
                        ((ln.EndPoint == lx.StartPoint) || (ln.EndPoint == lx.EndPoint)))
                        if (!ids.Contains(idx))
                            ids.Add(idx);
                            SelectConnectedLines(btr, ids, idx);
        public List<ObjectId> JoinLines(BlockTableRecord btr, ObjectId id)
            List<ObjectId> ids = new List<ObjectId>();
            SelectConnectedLines(btr, ids, id);
            return ids;
~'J'~
« Last Edit: July 08, 2012, 01:47:55 AM by fixo »
cincir
« Reply #9 on: July 08, 2012, 10:12:21 PM »
Thank you for the sample code fixo. but i have got a huge file and i have already tried this. believe me it is very time comsuming when iterate all the entities. but again thanks anyway.
Gasty
« Reply #10 on: July 09, 2012, 01:00:59 AM »
How many lines have in the dwg?, Can you use a third party library? if so, you can try with quick graph in this link: http://quickgraph.codeplex.com/ (it's free) you only need to create a graph (just an object of the library), add by range the vertex collection (nodes or line end points in this case) , and edge collection (the source and target vertex (node): the start and end point of each line)  and that's it, with 20 or less lines of code you have a query-able graph. The main issue with this approach is rounding, so you need to take care of that as the vertex collection need to be exclusive (no repeated nodes).
Gaston Nunez
« Reply #11 on: July 09, 2012, 01:12:34 AM »
cincir,
You may need to provide a bit more detail regarding what you expect.
Are you expecting to return a list of ALL lines that have connecting lines each end. ??
How big is your drawing ?
Do you have a sample ?
What time do you expect this calculation to take. ?
How do you imagine this could be done WITHOUT iterating the database ??
pkohut
« Reply #12 on: July 09, 2012, 01:36:40 AM »
Hey Fixo,
Some premature optimization here  :-D
1) check if ObjectId is in the container before comparing endpoints in SelectConnectedLines
2) Depending on number of potential objects the List<> can have, switch to a Dictionary or HybridDictionary class for SelectConnectedLines.
New tread (not retired) - public repo at https://github.com/pkohut
fixo
« Reply #13 on: July 09, 2012, 04:18:05 AM »
Hey Fixo,
Thanks Paul, this one is written quickly from scratch,
I will see what I can do, but would be this easier to
use selection set of lines on the current tab instead?
Regards,
Oleg
fixo
« Reply #14 on: July 09, 2012, 05:05:24 AM »
Try this one instead, it takes about 30 sec on 16000 lines on my machine
        [CommandMethod("testJoinLines", "tjl", CommandFlags.Modal | CommandFlags.UsePickSet)]//OK
               Layout lt = (Layout)tr.GetObject(btr.LayoutId, OpenMode.ForRead) as Layout;
               TypedValue[] values = new TypedValue[]
                        new TypedValue(0, "LINE") ,
                        new TypedValue(410, lt.LayoutName)
               SelectionFilter filter = new SelectionFilter(values);
               PromptSelectionResult result = ed.SelectAll(filter);
               if (result.Status != PromptStatus.OK) return;
               SelectionSet sset = result.Value;
                List<ObjectId> ids = JoinLines(sset, res.ObjectId);
                //or
                    return;
                tr.Commit();
        private void SelectConnectedSet(SelectionSet sset, List<ObjectId> ids, ObjectId id)
            if (ln != null)
                foreach (SelectedObject selobj in sset)
                    ObjectId idx = selobj.ObjectId;
                    if (!idx.IsValid) continue;
                            ids.Add(idx);
                            SelectConnectedSet(sset, ids, idx);
        public List<ObjectId> JoinLines(SelectionSet sset, ObjectId id)
            SelectConnectedSet(sset, ids, id);
            return ids;
~'J'~
