Sorry I dropped this thread, I must have missed a notification that it was updated, I didn't see any of the replies since my last post. Since, I've been pretty busy creating all my Autodesk 2013 install deployments scripts and acad.lsp files.
I have added the Raster Design support paths to my acad.lsp, and I have decided to install Raster design on all my AutoCAD installs, this way the product is available to everyone and is demand loaded as you have both suggested. It looks like it's working pretty well.
So now, Raster Design is set, to be installed on all my workstations, but now it's the other add-on apps tripping me up, like AutoTrack and Carlson. The way it looks like they run is, they each have their own shortcut that is installed with the program.
AutoTrack simply launches AutoCAD, runs a script to load the application and launch it within AutoCAD, and it also forces it's own profile, which it created during install off the default AutoCAD profile. My problem is, when using the AutoTrack shortcut and my acad.lsp, it does not appear the shortcut command line switches work, as it does not appear the script that the shortcut launches runs. Does the acad.lsp bypass the command line switches? When I disable my acad.lsp, the shortcut works fine and loads the application. Now, when I have my acad.lsp UNloaded so AutoTrack is running OK within it's own profile in AutoCAD, there are no support paths for it. Ideally, I would just like to load the AutoTRack menus with out loading the application so it works on demand like Raster Design. How would this be done without support paths?
I'm really kind of hesitant to go back to making multiple custom icons for all these applications because that is what I tried for the 2008 Autodesk releases when we adjusted our standards directory and had to remap all our support paths. It did the trick, but there was a lot of confusion with users, they usually found some of the default shortcuts, but the biggest problem with custom shortcuts is 98% of my users LOVE double clicking files directly from Windows Explorer or e-mails, which of course would bypass anything that was built into the shortcut command lines. I could do a better job of making sure all machines have the right shortcuts and ONLY the right shortcuts, but I don't know how I'd make sure people are still using them. I just had one of my users report he couldn't open AutoCAD at all, I found out it's because he was just double clicking a file, and it was defaulted to AutoCAD 2008 still, which we do not have licensed any more...
Sorry for the length of this, it's late, I'm going a bit of crazy :ugly:
Thanks!
