Author Topic: INITIALIZE NONE EXISTANT VAR  (Read 3522 times)
Re: INITIALIZE NONE EXISTANT VAR
« Reply #15 on: June 21, 2012, 01:55:00 PM »
Not sure what you mean.  If i open a dwg, and !cmdrun it come back nil, which i was trying to trap.
Are you actually running the function (DrawCable) before testing the variable?
David Hall
  • Automatic Duh Generator
« Reply #16 on: June 21, 2012, 02:01:18 PM »
Lee, i think yes.  When I first opened the dwg, the first command I called was (DrawCable)
Gasty
« Reply #17 on: June 22, 2012, 09:57:25 PM »
May be CMDRUN is set to a non numeric value like a string or a list, so it pass the test.
Gaston Nunez
irneb
« Reply #18 on: June 23, 2012, 02:24:58 AM »
Gaston Nunez
The biggest reason for localizing variables! Since now you have to go through every bit of code you ever had to try and find the culprit.
As a side note, to try and avoid this, when making such a global variable the convention is to prefix and suffix it with asterisks (to make it clear that it's meant as a global var). I.e. the var's name should be *CMDRUN* ... makes it easier to find in other codes as well, so your search becomes less daunting.
DEVITG
« Reply #19 on: June 23, 2012, 11:42:09 PM »
To  CmdrDuh
What value is set to osmode here ?
(setvar "orthomode" 0)
  (setvar "osmode"
  (setq   pt1 (getpoint "\nPick Cable Start: ")
If your task is only to draw 6 cable , why not to use a repeat.
(defun DrawCable (/
 ANG CLAY MPT OSM OTH PT1 PT2 PT3
  (setq clay (getvar "clayer"))
  (setq osm (getvar "osmode"))
  (setq oth (getvar "orthomode"))
  (repeat 6
    (setvar "osmode"  512);_ I set it to near to
   pt2 (getpoint pt1 "\nPick Cable Endpoint: ")
   ANG (ANGLE pt1 pt2)
  (setvar "osmode" 0)
  (SETQ mpt (POLAR pt1 (ANGLE pt1 pt2) (/ (DISTANCE pt1 pt2) 2)))
    ((AND (<=  ANG (/ pi 2 )) (>  ANG 0))  (setq pt3 (polar mpt (+ ang  ( / pi 2)) (/ (DISTANCE pt1 pt2) 5))))
    ((AND (<=  ANG pi ) (>  ANG ( / pi 2)))  (setq pt3 (polar mpt (- ang  ( / pi 2)) (/ (DISTANCE pt1 pt2) 5))))
    ((AND (<=  ANG ( * pi 1.5)) (>  ANg pi ))(setq pt3 (polar mpt (+ ang   ( / pi 2)) (/ (DISTANCE pt1 pt2) 5))))
    ((AND (<=  ANG ( * pi 2) ) (>  ANG ( * pi 1.5) ))(setq pt3 (polar mpt (- ang   ( / pi 2)) (/ (DISTANCE pt1 pt2) 5))))
    ((=  ANG 0)(setq pt3 (polar mpt (- ang   ( / pi 2)) (/ (DISTANCE pt1 pt2) 5))))
  (command "-layer" "m" "SITE-BUSS" "C" 1 "SITE-BUSS" "")
  (command "pline" pt1 "w" 2 2 "a" "s" pt3 pt2 "")
    );_ end repeat
  (setvar "orthomode" oth)
  (setvar "osmode" osm)
  (setvar "clayer" clay)
« Last Edit: June 24, 2012, 12:41:15 PM by DEVITG »
