Author Topic: visual lisp crash calling (command "draworder")  (Read 8962 times)
SIDESHOWBOB
Re: visual lisp crash calling (command "draworder")
« Reply #15 on: June 28, 2012, 10:34:14 AM »
No, it just says ; error: bad argument type: VLA-OBJECT
I tried loading your code, and modifying your catch all apply function as follows:
  1. (defun LM:CatchApply ( _function _params / result )
  2.     (if (not (vl-catch-all-error-p (setq result (vl-catch-all-apply _function _params))))
  3.         result
  4.         (progn (princ result) (princ))
  5.     )
  6. )
...same result
SIDESHOWBOB
« Reply #16 on: June 28, 2012, 10:37:07 AM »
And yes, dict receives a value <VLA-OBJECT IAcadDictionary 0bbc89a4>
SIDESHOWBOB
« Reply #17 on: June 28, 2012, 10:39:25 AM »
Test with your routines:
  1. #<%catch-all-apply-error%>
  2. ; error: bad argument type: VLA-OBJECT
LE3
« Reply #18 on: June 28, 2012, 11:09:44 AM »
might want to give it a try to this function:  VxSetDrawOrder - from one of the old masters in the lispy world...
here:
http://www.menziengineering.ch/Downloads/Download.htm
SIDESHOWBOB
« Reply #19 on: June 29, 2012, 10:50:37 AM »
here:
Interesting - the same command fails
  1. (vla-AddObject ExtDic "ACAD_SORTENTS" "AcDbSortentsTable")
but with a different error message
  1. error: Automation Error. AcRxClassName entry is not in the system registry
irneb
« Reply #20 on: July 02, 2012, 02:28:06 AM »
Which version of ACad are you using? Or do you use some clone instead? It sounds as if the ActiveX libraries weren't registered on your system. If ACad see if a repair install solves this.
Jürg Menzi
  • Oberegg, Switzerland
« Reply #21 on: July 02, 2012, 07:35:34 AM »
'VxSetDrawOrder' is tested with all Acad versions 2k5 - 2k12,
and 2k13 also... 8-)
Cheers
« Last Edit: July 02, 2012, 08:06:06 AM by Jürg Menzi »
MENZI ENGINEERING GmbH
SIDESHOWBOB
« Reply #22 on: July 02, 2012, 08:30:07 AM »
Must be my version of autocad then.  It's a direct link autodesk sent me after I complained the 2010 download was broken.
owenwengerd
« Reply #23 on: July 02, 2012, 10:28:26 AM »
The error means that the clas sname is not registered, which means the .arx module is not loaded. Does the DRAWORDER command work? If so, use it to demand load the module before attempting to use it. If not, check your DEMANDLOAD system variable setting.
« Reply #24 on: July 02, 2012, 11:57:36 AM »
1+
Otherwise, call this in your routine:
(if (not (member "acdorder.arx" (arx)))
    (arxload "acdorder.arx" nil)
