Author Topic: How can I to get the list of all types which objects are available in a drawing  (Read 9049 times)
Andrey Bushman
Hi all. Sorry for my bad English.
The dictionary of the identifiers grouped by types is necessary to me. If in a cycle each time I will check dictionary key existence (look a code below), then the code will be slower. I want to receive at first all keys, to add them in the dictionary, and only after that to take identifiers and to group them by dictionary keys. Look my commented code row:
Dictionary<string, List<ObjectId>> dict = new Dictionary<string, List<ObjectId>>();
using (Transaction t = Database.TransactionManager.StartTransaction()) {
for (long i = Database.BlockTableId.Handle.Value; i < Database.Handseed.Value; i++) {
ObjectId id = ObjectId.Null;
Handle h = new Handle(i);
if (IsValidHandle(h, ref id) && filter(t, id)) {
string type = id.ObjectClass.Name;
if (!dict.Keys.Contains(type))// <= My question about it code row - it isn't pleasant to me...
dict.Add(type, new List<ObjectId>());
dict[type].Add(id);
t.Abort();
How can I to get the list of all types which objects are available in a drawing database?
MexicanCustard
This is how I would do what you're showing without your method calls in the if statement.
        public static void Test()
            Database db = MgdAcApplication.DocumentManager.MdiActiveDocument.Database;
                var dict = new Dictionary<string, List<ObjectId>>();
                var btr = (BlockTableRecord) db.BlockTableId.GetObject(OpenMode.ForRead);
                foreach (ObjectId id in btr)
                    if (!dict.ContainsKey(id.ObjectClass.Name))
                        dict.Add(id.ObjectClass.Name, new List<ObjectId>());
                    dict[id.ObjectClass.Name].Add(id);
                tr.Commit();////Not neccessary
You realize that that your code is only generating a list of objects in the BlockTableRecord which are mostly going to be more BlockTableRecords.
« Last Edit: June 18, 2012, 12:51:25 PM by MexicanCustard »
kaefer
Sounds like IEnumerable.GroupBy<> could be for you.
Code - C#: [Select]
  1.         [CommandMethod("GroupObjectClassTest")]
  2.         static public void groupObjectClassTestCmd()
  3.         {
  4.             Database db = acadApp.DocumentManager.MdiActiveDocument.Database;
  5.             Editor ed = acadApp.DocumentManager.MdiActiveDocument.Editor;
  6.
  7.             ObjectId outId = ObjectId.Null;
  8.             Dictionary<RXClass,List<ObjectId>> res =
  9.                 generateHandles(db)
  10.                 .Select(hnd => new { ok = db.TryGetObjectId(hnd, out outId), id = outId })
  11.                 .Where(x => x.ok)
  12.                 .Select(x => x.id)
  13.                 .GroupBy(id => id.ObjectClass)
  14.                 .ToDictionary(grp => grp.Key, grp => grp.ToList());
  15.
  16.             foreach (KeyValuePair<RXClass,List<ObjectId>> kvp in res)
  17.                 ed.WriteMessage("\n{0}: {1} ", kvp.Key.Name, kvp.Value.Count);
  18.         }
  19.         static private IEnumerable<Handle> generateHandles(Database db)
  20.         {
  21.             for (Int64 i = db.BlockTableId.Handle.Value; i < db.Handseed.Value; i++)
  22.                 yield return new Handle(i);
  23.         }
Code - F#: [Select]
  1. [<CommandMethod "GroupObjectClassTest">]
  2. let groupObjectClassTestCmd() =
  3.     let db = acadApp.DocumentManager.MdiActiveDocument.Database
  4.     let ed = acadApp.DocumentManager.MdiActiveDocument.Editor
  5.
  6.     let res =
  7.         { db.BlockTableId.Handle.Value .. db.Handseed.Value - 1L }
  8.         |> Seq.map (fun i -> new Handle(i) |> db.TryGetObjectId)
  9.         |> Seq.filter fst
  10.         |> Seq.map snd
  11.         |> Seq.groupBy (fun oid -> oid.ObjectClass)
  12.         |> dict
  13.
  14.     for KeyValue(rx, oids) in res do
  15.         ed.WriteMessage("\n{0}: {1} ", rx.Name, Seq.length oids)
Se7en's EDIT: I apologize, but I am removing the geshi code tags from this message to check on an error in the forums database. ...I put the geshi code tags back.
« Last Edit: June 21, 2012, 11:08:24 AM by Se7en »
TheMaster
Before we reach into the MgdDbg grab-bag, could you clarify what you mean by 'objects' ?
Do you mean all database objects, or only entities?  If the latter, do you mean all entities
in all blocks, or only those in layout blocks, or only those in modelspace, etc.
I'm asking this because I can't see a need for that kind of operation for any type of
database object and every single object in a database, unless you are writing some
kind of database viewer or something.
Andrey Bushman
I thank all for answers. I will compare speeds of performance of a code.
It is very strange, since there is a lot of such tasks...
For example:
it is necessary to remove text style. But this style can be used by different primitives (the text, the sizes, attributes, etc.) therefore at first it is necessary to find all these primitives in a database and to appoint by it other text style. These primitives can be anywhere. The similar task can arise and for other styles: dimensional styles, table styles, etc.
DBObjects only.
If the latter, do you mean all entities in all blocks, or only those in layout blocks, or only those in modelspace, etc.
Above I specified an example. I hope, this example gives the clear answer to your question: it is necessary to look for everywhere since the necessary objects can be anywhere. If not to find at least one, then it will not be possible to remove text style.
« Last Edit: June 19, 2012, 02:08:13 AM by Andrey »
gile
  • Marseille, France
What about the Database.Purge() method ?
Andrey Bushman
What relation has this method to the specified task?
Andrey Bushman
2 kaefer
I wrote the test code measuring productivity:
using System;
using System.Linq;
using System.Text;
using Dgs = System.Diagnostics;
using AcApp = Autodesk.AutoCAD.ApplicationServices;
using acad = Autodesk.AutoCAD.ApplicationServices.Application;
using AcDb = Autodesk.AutoCAD.DatabaseServices;
using AcEd = Autodesk.AutoCAD.EditorInput;
using AcGem = Autodesk.AutoCAD.Geometry;
using AcCol = Autodesk.AutoCAD.Colors;
using AcRtm = Autodesk.AutoCAD.Runtime;
[assembly:AcRtm.CommandClass(typeof(SpeedTest.Testing))]
namespace SpeedTest {
public class Testing {
//to fill the Database with data...
[AcRtm.CommandMethod("FILLDATA")]
public void FillDatabase() {
AcApp.Document doc = acad.DocumentManager.MdiActiveDocument;
AcDb.Database db = doc.Database;
AcDb.HostApplicationServices.WorkingDatabase = db;
AcEd.Editor ed = doc.Editor;
ed.WriteMessage("\nInitialize started...");
using (AcDb.Transaction t = db.TransactionManager.StartTransaction()) {
Random rnd = new Random();
AcDb.BlockTable bt = t.GetObject(db.BlockTableId, AcDb.OpenMode.ForWrite) as AcDb.BlockTable;
AcDb.BlockTableRecord btr = t.GetObject(bt[AcDb.BlockTableRecord.ModelSpace], AcDb.OpenMode.ForWrite) as AcDb.BlockTableRecord;
DateTime startTime = DateTime.Now;
for (int i = 0; i < 2000000; i++) {
AcDb.Circle circle = new AcDb.Circle();
circle.SetDatabaseDefaults();
Double x = rnd.Next(0, 1000000);
Double y = rnd.Next(0, 1000000);
Double radius = rnd.Next(10, 1000);
circle.Center = new AcGem.Point3d(x, y, 0);
circle.Radius = radius;
Byte r = (Byte) rnd.Next(0, Byte.MaxValue);
Byte g = (Byte)rnd.Next(0, Byte.MaxValue);
Byte b = (Byte)rnd.Next(0, Byte.MaxValue);
AcCol.Color color = AcCol.Color.FromRgb(r,g,b);
circle.Color = color;
btr.AppendEntity(circle);
t.AddNewlyCreatedDBObject(circle, true);
t.Commit();
DateTime finishTime = DateTime.Now;
ed.WriteMessage("\nInitialize finished.\nInitialization time: {0}", finishTime - startTime);
[AcRtm.CommandMethod("var1")]
public void Variant1() {
Dictionary<string, List<AcDb.ObjectId>> dict = GetGroupedObjectIds((t, id) => true);
foreach (KeyValuePair<String, List<AcDb.ObjectId>> kvp in dict)
ed.WriteMessage("\n{0}: {1} ", kvp.Key, kvp.Value.Count);
public Dictionary<string, List<AcDb.ObjectId>> GetGroupedObjectIds(Func<AcDb.Transaction, AcDb.ObjectId, bool> filter) {
//Dgs.Debug.Assert(null != filter, "null != filter");
//if (null == filter)
//    throw new ArgumentNullException("Argument is null");
Dictionary<string, List<AcDb.ObjectId>> dict = new Dictionary<string, List<AcDb.ObjectId>>();
ed.WriteMessage("\nVariant №1 started...");
for (long i = db.BlockTableId.Handle.Value; i < db.Handseed.Value; i++) {
AcDb.ObjectId id = AcDb.ObjectId.Null;
AcDb.Handle h = new AcDb.Handle(i);
if (db.TryGetObjectId(h, out id)  && !id.IsNull && id.IsValid && filter(t, id)) {
dict.Add(type, new List<AcDb.ObjectId>());
dict[type].Add(id);
t.Abort();
ed.WriteMessage("\nVariant №1 finished.\nOperation time: {0}", finishTime - startTime);
return dict;
[AcRtm.CommandMethod("var2")]
public void Variant2() {
AcDb.ObjectId outId = AcDb.ObjectId.Null;
ed.WriteMessage("\nVariant №2 started...");
Dictionary<AcRtm.RXClass, List<AcDb.ObjectId>> res =
generateHandles(db)
id = outId
.Where(x => x.ok)
.Select(x => x.id)
ed.WriteMessage("\nVariant №2 finished.\nOperation time: {0}", finishTime - startTime);
foreach (KeyValuePair<AcRtm.RXClass, List<AcDb.ObjectId>> kvp in res)
static private IEnumerable<AcDb.Handle> generateHandles(AcDb.Database db) {
yield return new AcDb.Handle(i);
Result:
Command: netload
Command: var1
Operation time: 00:00:02.6561650
AcDbBlockTable: 1
AcDbLayerTable: 1
AcDbTextStyleTable: 1
AcDbLinetypeTable: 1
AcDbViewTable: 1
AcDbUCSTable: 1
AcDbViewportTable: 1
AcDbRegAppTable: 1
AcDbDimStyleTable: 1
AcDbDictionary: 16
AcDbDictionaryWithDefault: 1
AcDbPlaceHolder: 1
AcDbLayerTableRecord: 1
AcDbTextStyleTableRecord: 2
AcDbRegAppTableRecord: 7
AcDbLinetypeTableRecord: 3
AcDbMlineStyle: 1
AcDbBlockTableRecord: 3
AcDbBlockBegin: 3
AcDbBlockEnd: 3
AcDbLayout: 3
AcDbDimStyleTableRecord: 3
AcDbDictionaryVar: 7
AcDbTableStyle: 1
AcDbViewportTableRecord: 1
AcDbMaterial: 3
AcDbVisualStyle: 16
AcDbScale: 17
AcDbMLeaderStyle: 2
AcDbXrecord: 5
AcDbCircle: 2000000
AcDbCellStyleMap: 1
AcDbFontTable: 1
AcDbVXTable: 1
AcDbFontTableRecord: 2
Command: var2
Operation time: 00:00:02.5936670
AcDbBlockTable: 1
AcDbLayerTable: 1
AcDbViewTable: 1
AcDbUCSTable: 1
AcDbRegAppTable: 1
AcDbDictionary: 16
AcDbPlaceHolder: 1
AcDbMlineStyle: 1
AcDbBlockBegin: 3
AcDbBlockEnd: 3
AcDbLayout: 3
AcDbTableStyle: 1
AcDbMaterial: 3
AcDbVisualStyle: 16
AcDbScale: 17
AcDbMLeaderStyle: 2
AcDbXrecord: 5
AcDbCircle: 2000000
AcDbCellStyleMap: 1
AcDbFontTable: 1
AcDbVXTable: 1
Your code works quicker.
« Last Edit: June 19, 2012, 05:11:08 AM by Andrey »
Andrey Bushman
2 kaefer
But if I change your code so (I think, that these checks need to be added in a code):
ok = db.TryGetObjectId(hnd, out outId) && !outId.IsNull && outId.IsValid,
and
KeyValuePair<String, List<AcDb.ObjectId>I change key type.
Then my code works quickly than your:
Operation time: 00:00:02.8905325
Operation time: 00:00:03.1405245
Operation time: 00:00:02.8280345
Operation time: 00:00:02.9217815
Operation time: 00:00:02.5780425
Operation time: 00:00:02.9061570
« Last Edit: June 19, 2012, 05:15:29 AM by Andrey »
irneb
I'm with gile on this. The Database.Purge() method, does not purge the styles / blocks / etc. It simply filters out those which cannot be purged. As a sample of its use, see Kean Walmsley's example code for "purging" unused Annotation Scales: http://through-the-interface.typepad.com/through_the_interface/2008/05/deleting-unused.html
Andrey Bushman
I need to remove styles which break our corporate standard. But these styles are used by primitives. Thus the Purge method won't help with this situation.
irneb
OK, so you want to get thew entities / objects which refer to the styles you want out of there. Sorry, from your post I must've misunderstood.
I.e. you want to change them to a "standard" style according to your settings? Now I understand! Sorry, it does seem that you're on the right track then - unless someone knows of a way to get at the internals of that Purge method. I'm guessing it does much the same thing internally as you are trying now: i.e. stepping through the entire database to see if there's something which is referring to the set of styles.
owenwengerd
There is no robust way using the .NET API to find all referencing objects. You can look for references from known object types, but even known object types can have references in unusual ways (attached reactor, xdata, unanticipated new references in a new version of the object). The only robust way to get all interobject references is to file every object to a DXF or DWG filer, which is only possible using the ObjectARX API.
Andrey Bushman
It is interesting. Can you write an example a code which are showing the problem about what you tell?
Regards
TheMaster
There certainly is a robust way to do that with .NET.
Code - C#: [Select]
  1.
  2. public class RefSearchFiler : Autodesk.AutoCAD.DatabaseServices.DwgFiler
  3. {
  4.   private ObjectId referencedId;
  5.   private DBObject current = null;
  6.
  7.   private ObjectIdCollection referencingObjectIds = new ObjectIdCollection();
  8.
  9.   // Pass the Id of the object to find references to:
  10.
  11.   public RefSearchFiler( ObjectId referencedId )
  12.   {
  13.     this.referencedId = referencedId;
  14.   }
  15.
  16.   // Search the parameter for references to the referencedId:
  17.
  18.   public void Find( DBObject obj )
  19.   {
  20.     this.current = obj;
  21.     try
  22.     {
  23.       obj.DwgOut( this );
  24.     }
  25.     finally
  26.     {
  27.       this.current = null;
  28.     }
  29.   }
  30.
  31.   // The ObjectIds of all referencing objects:
  32.
  33.   public ObjectIdCollection ReferencingObjectIds
  34.   {
  35.     get
  36.     {
  37.       return referencingObjectIds;
  38.     }
  39.   }
  40.
  41.   public override void WriteSoftOwnershipId( ObjectId value )
  42.   {
  43.     OnWriteReference( value );
  44.   }
  45.
  46.   public override void WriteSoftPointerId( ObjectId value )
  47.   {
  48.     OnWriteReference( value );
  49.   }
  50.
  51.   public override void WriteHardOwnershipId( ObjectId value )
  52.   {
  53.     OnWriteReference( value );
  54.   }
  55.
  56.   public override void WriteHardPointerId( ObjectId value )
  57.   {
  58.     OnWriteReference( value );
  59.   }
  60.
  61.   // In this case, we don't care about whether a reference
  62.   // is hard/soft/owner/pointer, but we could discriminate
  63.   // further if needed.
  64.
  65.   void OnWriteReference( ObjectId value )
  66.   {
  67.     if( value == referencedId && this.current != null )
  68.     {
  69.       referencingObjectIds.Add( this.current.ObjectId );
  70.       this.current = null;
  71.     }
  72.   }
  73. }
  74.
  75.
   :laugh:
« Last Edit: June 21, 2012, 11:09:05 AM by Se7en »
