Author Topic: Can't get the dotted list '(1 . nil) ?  (Read 2600 times)
highflyingbird
  • Later equals never.
« on: June 14, 2012, 08:25:12 PM »
When I use this ,  (list 1 . nil),actually, I want a dotted list, like this: '(1 . nil) but the result is:    (1).   even  I  use this way :  (cons 1 nil)    and  (quote( 1 nil))   ,I can't get I wanted.
So I see the vlisp help:
The value returned depends on the data type of list-or-atom. If list-or-atom is a list, cons returns that list with new-first-element added as the first item in the list. If list-or-atom is an atom, cons returns a dotted pair consisting of new-first-element and list-or-atom.
but:
(atom nil) ---> T
(listp nil)---> T
So, I think : there is no way to the that kind of  dotted list,is that true?
I am a bilingualist,Chinese and Chinglish.
Re: Can't get the dotted list '(1 . nil) ?
« Reply #1 on: June 14, 2012, 09:22:00 PM »
Perhaps you could explain why you need that construct?
highflyingbird
« Reply #2 on: June 14, 2012, 09:28:10 PM »
I want to build a binomial tree model. when the right node is empty, I use  nil to express it.
« Reply #3 on: June 14, 2012, 10:47:09 PM »
This is what I use.
  1.  ;|--------------------------------------------------------
  2. Function: (KDUB:Dotted-Pair-p arg )
  3. RETURN : T if arg is a dotted-pair list
  4. nil otherwise
  5. Notes:
  6. Anything that is not a list is considered an atom. NIL is an atom.
  7. ----------------------------------------------------------|;
  8.
  9. (defun kdub:dotted-pair-p (arg) (and (not (atom arg)) (not (listp (cdr arg)))))
  10.
  11.  ;|---------------------------------------------------------
  12. Function: (KDUB:normal-list-p   arg )
  13. RETURN : T if arg is a list
  14. nil if arg is atom or nil or dotted-pair list
  15. EXAMPLE:
  16. (KDUB:normal-list-p nil)       ==>> nil
  17. (KDUB:normal-list-p "abc")    ==>> nil
  18. (KDUB:normal-list-p '(1 . 3 )) ==>> nil
  19. (KDUB:normal-list-p '((1 2 3)(4 5 6)) ) ==>> T
  20. (KDUB:normal-list-p '((1 2 3)(4 . 5)(a b c)) ) =>> T
  21. (KDUB:normal-list-p '((1 . "first")(2 . "second")) ) ==>> T
  22. (KDUB:normal-list-p (car '((1 . "first")(2 . "second")) )) ==>> nil
  23. (KDUB:normal-list-p (car '(("a" "first")(2 . "second")) )) ==>> T
  24. ----------------------------------------------------------|;
  25. (defun kdub:normal-list-p (arg / return)
  26.   (setq return (if (not (atom arg))
  27.                  (vl-list-length arg)
  28.                  nil
  29.                )
  30.   )
  31.   (if (or (not return) (zerop return))
  32.     nil
  33.     t
  34.   )
  35. )
  36.
  37.  ;|---------------------------------------------------------|;
  38.
  1.
  2. (setq result (cons 8 nil))
  3.
  4. (kdub:dotted-pair-p result)  ;;-> nil
  5.
highflyingbird
« Reply #4 on: June 14, 2012, 11:21:06 PM »
This is what I use.
Thanks ,Kerry. this is a good way.
« Reply #5 on: June 14, 2012, 11:30:56 PM »
You're welcome :)
ribarm
  • Marko Ribar, architect
« Reply #6 on: June 14, 2012, 11:51:57 PM »
nil is protected symbol, maybe you can use any other variable and eval them in calculations of dotted pair...
  1. (setq n T)
  2. (eval (cdr (cons 1 'n)))
  3. ---> T
  4.
n - variable assigned value T
  1. (setq n nil) <--- if variable haven't previously been used, you can skip this line
  3. ---> nil
  4.
n - variable not defined
  1. (cons 1 'n)
  2. ---> (1 . N)
  3.
constructed dotted pair with symbol-atom 1 and unprotected symbol-atom N
also consider this :
  1. (cons 1 nil)
  2. ---> (1)
  3. (eval (cdr (cons 1 nil)))
  4. ---> nil  just like  (cons 1 nil)->(1 . nil)
  5.
  6. if (setq T nil)
  7. (cons 1 T)
  8. ---> (1 . T)
  9. (eval (cdr (cons 1 T)))
  10. ---> nil  just like (cons 1 T)->(1)->(1 . nil)
  11.
  12. else if T undefined
  13. (cons 1 T)
  14. ---> (1 . T)
  15. (eval (cdr (cons 1 T)))
  16. ---> T
  17.
as you wrote :
(atom nil) -> T
(listp nil) -> T
(eval nil) -> nil
but
(atom T) -> T  (atom 1) -> T  (atom N) -> T
(listp T) -> nil  (listp 1) ->nil  (listp N) -> nil
and
(eval T) -> T  (eval 1) -> 1  (eval N) -> nil
M.R.
« Last Edit: June 15, 2012, 12:13:50 AM by ribarm »
M.R. on Youtube
Faster
« Reply #7 on: June 15, 2012, 12:13:31 AM »
(setq a '(1 . 2) b '(1 . nil) c '(1))
(car a) ==> 1  (cdr a) ==> 2
(car b) ==> 1 (cdr b) ==> nil
(car c) ==> 1 (cdr c) ==> nil
so
b = c   :  (equal '(1 . nil) '(1)) ==> t
irneb
« Reply #8 on: June 15, 2012, 07:22:05 AM »
I think you're over-complicating the binary tree structure: Consider this:
  1. (defun BTree:GetVal (node /) (car node))
  2. (defun BTree:GetLeft (node /) (cadr node))
  3. (defun BTree:GetRight (node /) (caddr node))
  4. (defun BTree:SetVal (node val /) (list val (BTree:GetLeft node) (BTree:GetRight node)))
  5. (defun BTree:SetLeft (node left /) (list (BTree:GetVal node) left (BTree:GetRight node)))
  6. (defun BTree:SetRight (node right /) (list (BTree:GetVal node) (BTree:GetLeft node) right))
  7.
  8. (setq TestTree1 '(1 (2 (4 (8)) (5)) (3 (6) (7)))
  9.       TestTree2 '(1 (2 (4 (8) (9)) (5 (10) (11))) (3 (6 (12) (13)) (7 (14) (15)))))
  10.
  11. (defun BTree:Height  (node /)
  12.   (if node
  13.     (1+ (max (BTree:Height (BTree:GetLeft node)) (BTree:Height (BTree:GetRight node))))
  14.     0))
  15.
  16. (defun BTree:GetLevel  (root level / GetLevel)
  17.   (defun GetLevel  (node count /)
  18.     (cond ((null node) nil)
  19.           ((zerop count) (list (BTree:GetVal node)))
  20.           (t (append (GetLevel (BTree:GetLeft node) (1- count)) (GetLevel (BTree:GetRight node) (1- count))))))
  21.   (GetLevel root level))
  22.
  23. (defun BTree:Traverse-ByLevel (root func / n height)
  24.   (setq n -1
  25.         height (BTree:Height root))
  26.   (while (< (setq n (1+ n)) height)
  27.     (mapcar 'func (BTree:GetLevel root n))))
E.g.
_$ (BTree:Traverse-ByLevel TestTree1 print)
1
2
3
4
5
6
7
8 (8)
« Reply #9 on: June 15, 2012, 07:29:04 AM »
Regarding binary trees, unless I have misunderstood, maybe the following thread will help you, reading from this post onwards:
http://www.theswamp.org/index.php?topic=35191.msg404387#msg404387
irneb
« Reply #10 on: June 15, 2012, 07:31:15 AM »
Or a more "proper" level traversal function and including blank nodes as nil values:
  1. (defun BTree:GetLevel  (root level / GetLevel)
  2.   (defun GetLevel  (node count /)
  3.     (cond ((null node) '(nil))
  4.           ((zerop count) (list (BTree:GetVal node)))
  5.           (t (append (GetLevel (BTree:GetLeft node) (1- count)) (GetLevel (BTree:GetRight node) (1- count))))))
  6.   (GetLevel root level))
  7.
  8. (defun BTree:Traverse-ByLevel (root func-node func-level / n height)
  9.   (setq n -1
  10.         height (BTree:Height root))
  11.   (while (< (setq n (1+ n)) height)
  12.     (func-level n)
  13.     (mapcar 'func-node (BTree:GetLevel root n)))
  14.   (princ))
Then watch this  :laugh: :
(lambda (val) (prin1 val) (princ "\t"))
(lambda (n) (princ "\nLevel ") (princ n) (princ ":\t")))
Level 0:    1
Level 1:    2    3
Level 2:    4    5    6    7
Level 3:    8    nil    nil    nil    nil    nil    nil    nil
Note though, my level traversal is extremely inefficient. You'd probably be better off using some sort of queue structure and iteration.
My point exactly, nested lists is exactly a tree structure in Lisp. Binary trees are simply nested lists which never have more than 2 items for each list (value left-list right-list).
irneb
« Reply #11 on: June 15, 2012, 07:55:52 AM »
Sorry, make that 3 items per list  :-[
