Author Topic: Lisp to allow exploding for all blocks  (Read 12187 times)
HasanCAD
« on: June 12, 2012, 10:00:46 AM »
How to make make this lisp for selection set
(defun c:AllowExplode (/ blocks)
  ;(prompt "\nSelect Blocks to Allow exploding")
  ;(setq Blk (ssget "_X" '(0 "BLOCK")))
  (setq blocks (vla-get-Blocks
(vla-get-ActiveDocument (vlax-get-acad-object))))
  (initget 0 "Yes No")
  (setq ans (cond ((getkword "\nYou want to aloow wxploding for blocks?  [Yes/No] <Yes>: ")) ("Yes") ) )
  (if (= ans "Yes")
    (setq ans :vlax-true)
    (setq ans :vlax-false))
  (vlax-for bl blocks (vla-put-explodable bl ans))
Re: Lisp to allow exploding for all blocks
« Reply #1 on: June 12, 2012, 10:05:21 AM »
Iterate over the selection set of blocks to be processed and collect a list of block names of selected blocks, then, when iterating over the block collection, only process those blocks whose name appears in the list.
Example to obtain such a list:
  1. (if (setq sel (ssget '((0 . "INSERT"))))
  2.     (repeat (setq inc (sslength sel))
  3.         (setq blk (cdr (assoc 2 (entget (ssname sel (setq inc (1- inc)))))))
  4.         (if (not (member blk lst))
  5.             (setq lst (cons blk lst))
  6.         )
  7.     )
  8. )
The above is sufficient for standard blocks; if Dynamic Blocks are used, you will need to retrieve the Effective Block Name instead of the name (which will be anonymous for some Dynamic Blocks).
HasanCAD
« Reply #2 on: June 14, 2012, 04:47:16 AM »
Gives error
error: bad argument type: VLA-object collection: ("Grid-100")
(defun c:AllowExplode (/ doc sel inc blk lst ans bl)
  (setq doc (vla-get-Blocks (vla-get-ActiveDocument (vlax-get-acad-object))))
            (setq lst (cons blk lst)))))
    (setq ans (cond ((getkword "\nDo you want to allow exploding for blocks?  [Yes/No] <Yes>: ")) ("Yes") ) )
    (if (= ans "Yes")
  (vlax-for bl lst (vla-put-explodable bl ans))
pBe
« Reply #3 on: June 14, 2012, 05:08:01 AM »
this
  1. (vlax-for bl lst (vla-put-explodable bl ans))
to
  1. (foreach bn lst  (vla-put-explodable (vla-item doc bn) ans))
oops  :-D
« Last Edit: June 14, 2012, 05:11:51 AM by pBe »
HasanCAD
« Reply #4 on: June 14, 2012, 05:34:13 AM »
this
to
Working perfect
Thanks pBe
pBe
« Reply #5 on: June 14, 2012, 05:51:35 AM »
Good For you HasanCAD
As Lee pointed out:
consider
  1. (setq blk (vla-get-EffectiveName (vlax-ename->vla-object (ssname sel (setq inc (1- inc))))))
« Reply #6 on: June 14, 2012, 07:06:47 AM »
Gives error
The 'lst' variable in my code is a list data type, not a VLA Collection Object.
HasanCAD
« Reply #7 on: June 14, 2012, 07:34:44 AM »
In fact your reply guided me to finish the code.
I tried LM:ss->vla but not working.
But when pBe told me about foreach I found the mistake.
My dealing was with the list as a one group but in fact I have to deal with one object each time.
this is my analysis of this error.
« Reply #8 on: June 14, 2012, 07:39:46 AM »
LM:ss->vla requires a Selection Set argument, not a list of strings.
ribarm
  • Marko Ribar, architect
« Reply #9 on: June 14, 2012, 09:23:18 AM »
HasanCAD, see if this thread from AUGI can help you...
M.R.
M.R. on Youtube
