Author Topic: Which Way is better to use in equation?  (Read 3455 times)
HasanCAD
« on: June 11, 2012, 11:12:18 AM »
Eq1: I make VAR for each step
Eq2: is less steps
Both give the same result
So, Which one is better to use?
Eq1
(setq Dst2 (/ Dist 2)
Dst1 (* 0.1 Dist)
S    (* 0.8 Dist)
SS   (* S S)
SS2  (/ SS 2)
SS4  (/ SS 4)
S42  (- SS4 SS2)
X1   (* idx step)
X    (- (* idx step) Dst1)
XX   (* X X)
Lc   (- *L* *c*)
Lc1  (* Lc 0.1)
LcD  (* Lc1 Dist)
a1   (/ LcD Dst2)
ys1  (- *L* a1)
yc   (- *c* ys1)
A    (/ yc S42)
AS   (* A S)
B    (- AS)
XXA  (* A XX)
XB   (* B X)
XAB  (+ XXA XB)
y    (+ XAB ys1)
yt   (rtos (round y 5) 2 0)
Eq2
(setq X    (- (* idx step) (* 0.1 Dist))
A    (/ (- *c* (- *L* (/ (* (* (- *L* *c*) 0.1) Dist) (/ Dist 2))))
(- (/ (* (* 0.8 Dist) (* 0.8 Dist)) 4) (/ (* (* 0.8 Dist) (* 0.8 Dist)) 2)))
B    (- (* A (* 0.8 Dist)))
XB   (* B X)
yt (rtos (round (+ (+ (* A (* X X)) (* B X)) (- *L* (/ (* (* (- *L* *c*) 0.1) Dist) (/ Dist 2)))) 5) 2 0)
Re: Which Way is better to use in equation?
« Reply #1 on: June 11, 2012, 11:32:07 AM »
Untested, but I think the whole thing could be simplified to:
  1. (setq X  (- (* idx step) (* 0.1 Dist))
  2.       C  (- *L* (* (- *L* *c*) 0.2))
  3.       A  (/ (- *c* C) (* -0.16 Dist Dist))
  4.       yt (rtos (round (+ (* A X X) (* -0.8 A X Dist) C) 5) 2 0)
  5. )
irneb
« Reply #2 on: June 11, 2012, 11:48:36 AM »
There's no right answer. It depends on what you want to do.
My rule of thumb is: If you only use the value once somewhere else, then rather just calculate it where it's needed. If you use it 2 or more times somewhere else, then it's more efficient to save it into a variable and reference it in the other places. In such case it's between speed efficiency and memory use. If you only use the variable once, then there's no speed efficiency gain, but you're using extra RAM for no reason.
E.g. in your 1st codes: S42 is only used once to calculate A. But to get to S42 you used SS twice. So I'd omit S42, S44 & S22. Take this as a sample though, there are many others with similar efficiency gains / minimizing unneeded RAM use.
The only possible reason I'd consider to make a variable where it's only going to be used once - is if I'd like to use it to make the code more readable. Though that's very seldom the case.
HasanCAD
« Reply #3 on: June 11, 2012, 11:53:09 AM »
  5. )
I was not asking about simplifying the equation, but I found your way is very good and I'll replace mine with yours when test and get the same results.
As usual awesome.
My question is which way is better to make a lot of variables or making a long equation with less VAR
Lets say
Eq1 (LEE)
Eq2
(setq yt (rtos (round (+ (* (/ (- *c* (- *L* (* (- *L* *c*) 0.2))) (* -0.16 Dist Dist))
    (- (* idx step) (* 0.1 Dist)) (- (* idx step) (* 0.1 Dist)))
(* -0.8 A (- (* idx step) (* 0.1 Dist)) Dist) (- *L* (* (- *L* *c*) 0.2)))
      5) 2 0)
HasanCAD
« Reply #4 on: June 11, 2012, 11:56:32 AM »
Thanks irneb I got it
zoltan
« Reply #5 on: June 12, 2012, 09:20:59 AM »
(setq   yt   (rtos (round (+ (+ (* (/ (- *c* (- *L* (/ (* (* (- *L* *c*) 0.1) Dist) (/ Dist 2)))) (- (/ (* (* 0.8 Dist) (* 0.8 Dist)) 4) (/ (* (* 0.8 Dist) (* 0.8 Dist)) 2))) (* (- (* idx step) (* 0.1 Dist)) (- (* idx step) (* 0.1 Dist)))) (* (- (* (/ (- *c* (- *L* (/ (* (* (- *L* *c*) 0.1) Dist) (/ Dist 2)))) (- (/ (* (* 0.8 Dist) (* 0.8 Dist)) 4) (/ (* (* 0.8 Dist) (* 0.8 Dist)) 2))) (* 0.8 Dist))) (- (* idx step) (* 0.1 Dist)))) (- *L* (/ (* (* (- *L* *c*) 0.1) Dist) (/ Dist 2)))) 5) 2 0)
This is clearly the right answer!  :lmao:
HasanCAD
« Reply #6 on: June 12, 2012, 10:03:57 AM »
(setq   yt   ...)
WHat  :evil: you are
LibertyOne
« Reply #7 on: June 12, 2012, 11:14:46 AM »
This seems to be a quite lengthly equation. Why not create a function for the equation?
« Reply #8 on: June 12, 2012, 11:27:38 AM »
The only real issue with defining variables is that lisp by default makes all variables global in nature unless you specify them to be local. This can create a problem across multiple functions. For example:
(defun foo ()
 (setq a 10)
(defun bar ()
  (princ a)
For simple functions it is readily apparent, however as functions grow in size and scope, it may pick up an inadvertent value .. for example:
(defun foo ()
 (setq a 10)
(defun bar ()
  (princ a)
(defun test()
 (setq a 42)
 (foo)
 (bar)
As you can see the result isn't what one might expect after looking at the code for test.
HasanCAD
« Reply #9 on: June 12, 2012, 11:37:31 AM »
I did. This is the code
irneb
« Reply #10 on: June 12, 2012, 11:56:41 AM »
That might be another reason to keep the number of variables down: So you don't have to include so many localized variables.
BTW, does anyone know if there's a lot of efficiency loss to assign a value to a variable through setq as opposed to simply using the value in a calculation? I'd imagine there's a very small amount of extra time to set a symbol and then use it as reference instead of simply using the value in place of the reference. Perhaps not much of a reason in that code though, since it only does the calculation after user interaction - but could make for slower running code if in a loop.
« Reply #11 on: June 12, 2012, 02:14:39 PM »
May years ago I read some development notes on lisp and the original concept didn't include variables because it was an interpreted language. Variables were added in the original development because it was determined that it was extremely useful to have them, for example in passing values between functions, also the fact that functions themselves are actually variables makes it hard to argue against using them.
I generally only use variables where required by the constraints of code. Where possible, I compartmentalize functions for efficiency and usability and limit the variables to those whose scope is readily useful in other portions of the function. I don't use globals at all (well except for the functions themselves), due to the problem I indicated previously.
