Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
Code Red
.NET
Topic:
AutoCAD Developer's Guide
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: AutoCAD Developer's Guide (Read 2810 times)
TJK44
Guest
on:
June 01, 2012, 05:46:26 PM »
Is there an AutoCAD Developer's Guide available in PDF format like the
AutoCAD Civil 3D Dev Guide
Logged
Mesozoic relic
Seagull
class keyThumper<T>:ILazy<T>
Re: AutoCAD Developer's Guide
Reply #1 on:
June 01, 2012, 06:35:58 PM »
Logged
It's Alive!
Retired
Needs a day job
AKA Daniel
WWW
Reply #2 on:
June 01, 2012, 11:57:06 PM »
Logged
https://github.com/CEXT-Dan/PyRx
https://pyarx.blogspot.com/
TJK44
Guest
Reply #3 on:
June 04, 2012, 07:56:05 AM »
Haha, I guess that would make too much sense?
Logged
dgorsman
Water Moccasin
Reply #4 on:
June 04, 2012, 10:27:45 AM »
Look at it this way: a good portion of the content would be seriously compromised with the changes in 2013.
Logged
try {GreatPower;}
catch (notResponsible)
{NextTime(PlanAhead);}
finally
{MasterBasics;}
TJK44
Guest
Reply #5 on:
June 04, 2012, 10:37:03 AM »
Good point dgorsman.
Logged
huiz
Swamp Rat
Certified Prof C3D
Reply #6 on:
June 04, 2012, 04:00:18 PM »
A few weeks ago I found the API Developers guide Civil3D 2013 in pdf, so I've downloaded it. Now I can only find the online API guide, just like the AutoCAD guides.
I rather have pdfs.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Code Red
.NET
Topic:
