Author Topic: Hatch routine  (Read 2761 times)
TJAM51
Hatch routine
« on: February 24, 2005, 10:40:51 AM »
The following routine has the ability to select objects for hatching by picking........how can this routine be modified to include the ability to select inside an area for hatching as well?
(defun c:h (/ sSet *error*)
  (defun *error* (msg)
    (setvar "cmdecho" 1)
    ); end *error*
  (setvar "cmdecho" 0)
  (princ "*** Select objects for Hatch & press [Enter] ")
  (terpri)
(command "hatch" "" "" "")
  (while (= 1 (getvar "cmdactive"))
    (command pause)
    ); end while
  (command "")
Andrea
Hatch routine
« Reply #1 on: February 24, 2005, 12:41:54 PM »
(setq ent1 (getpoint "*** Select POINT for Hatch "))
(command "_.-bhatch" ent1 "" "")
Keep smile...
Serge J. Gianolla
Hatch routine
« Reply #2 on: February 24, 2005, 06:05:42 PM »
Or you can always fiddle with the last routine in discussion:
http://www.theswamp.org/phpBB2/viewtopic.php?t=1890&highlight=bpoly
