Author Topic: ACA/MEP Property with formula eInvalidInput  (Read 2308 times)
MexicanCustard
« on: May 31, 2012, 04:19:07 PM »
I get an eInvalidInput error when this code to insert a formula property executes.
var descDef = new PropertyDefinitionFormula();
descDef.SetToStandard(db);
descDef.SubSetDatabaseDefaults(db);
descDef.Name = "Description";
descDef.UseFormulaForDescription = true;
psd.Definitions.Add(descDef);
descDef.SetFormulaString("X");  <--- Right here I get an eInvalidInput error
the actual formula looks like this:
const string formula =
                        "If \"[ObjectType]\" = \"PIPE\" Then\r\n\tRESULT=\"[PartSizeName]\" & \" X \" & \"[CutLength]\"\r\nElse\r\n\tRESULT=\"[PartSizeName]\"\r\nEnd If";
It doesn't matter what type of string I use in the SetFormulaString method call I get an eInvalidInput.  So I'm thinking there has got to be another property that needs to be set a certain way before I can set the formula.  The sample in the MEP help files is written identical to my code posted above.
MexicanCustard
Re: ACA/MEP Property with formula eInvalidInput
« Reply #1 on: June 05, 2012, 08:07:39 AM »
Bump!  Nobody?
MexicanCustard
« Reply #2 on: June 05, 2012, 09:15:54 AM »
Found the problem.
The PropertySetDefinition must be added to the DictionaryPropertySetDefinitions and Transaction.AddNewlyCreatedDBObject() called before the PropertyDefinitionFormula can be added to the PropertySetDefinition.  Works fine after that.
kaefer
« Reply #3 on: June 05, 2012, 04:47:43 PM »
Found the problem.
Congrats.
It says as much in Sample\CS.NET\AecPropertyDefinitionFormulaSampleMgd\AecPropertyDefinitionFormulaSampleMgd.cs:
    // we need to add all the automatic properties prior to the formula property
    // then we add the property set definition to the dictionary to make formula property work properly
    // before setting formula string to the formula property, we need to make sure
    // that the property definition is added to the property set definition (which has an object id)
In addition, it appears beneficial to call SetAppliesToFilter on the definition.
