Open DTM, i've been working on for a week now, all i get is a flashing hour glass. Have to force C3D to close.
Validating objects in the handle table.Valid objects 13677 Invalid objects 0Validating objects completed. Salvaged database from drawing.Auditing HeaderAuditing TablesAuditing Entities Pass 1Pass 1 13600 objects auditedAuditing Entities Pass 2Pass 2 9200 objects auditedAcDb3dPolylineVertex(947A) layer != owner's set to owner'sAcDb3dPolylineVertex(948C) layer != owner's set to owner'sPass 2 10100 objects auditedAcDb3dPolylineVertex(9E38) layer != owner's set to owner'sAcDb3dPolylineVertex(9E6A) layer != owner's set to owner'sPass 2 10900 objects auditedAcDb3dPolylineVertex(A58D) layer != owner's set to owner'sPass 2 12500 objects auditedAcDb3dPolylineVertex(B45E) layer != owner's set to owner'sPass 2 13600 objects auditedAuditing Blocks 17 Blocks auditedAuditing AcDsRecordsTotal errors found 6 fixed 6Erased 0 objectsOpening an AutoCAD 2013 format file.Resolve Xref "FREMONT LINEAR PARK TOPO": C:\Projects\FREMONT LINEAR PARK\FREMONT LINEAR PARK TOPO.dwgRegenerating model.AutoCAD menu utilities loaded.AutoCAD menu utilities loaded.Command:Autodesk DWG. This file is a TrustedDWG last saved by an Autodesk application or Autodesk licensed application.
