Based on your dwg, I would proceed thusly:
1) Select all TEXT objects on two layers which call out the additional bars.
2) For each TEXT object, find the closest TEXT object on the layer which specifies the dimension (extents) of the extra reinforcing, and which is perpendicular to the additional bar callouts. There appear to be some cases where this TEXT is missing.
3) Convert the latter TEXT object to a number, and use this number in conjunction with the bar spacing (what determines the bar spacing?) to calculate the number of bars for each TEXT object which specifies additional bars.
4) Keep a running total of each type of bar, and iterate all TEXT objects selected in #1.
5) Report # bars of each type upon completion.
You do not say if you have any AutoLISP experience.
If not, this would be an excellent chance to learn.
There are many talented people here who will be willing to help if you make the effort to learn.
Post your code.
And welcome to the swamp.
