@Lee, @Daniel, @Gilles, @Evgeniy, @Owen, @Highflybird, ... and others, tell me how to continue, but not to loose speed too much...
Where are the code comments?
Want speed - get out of lisp.
Want speed - keep nested loops to a minimum.
Want speed - don't do heavy calculations deep in the loops.
Want speed - don't do if checks deep in the loops.
Want speed - learn algorithms and data structures.
Why do you need code comments?
For other opinions I agree, but not my field of knowledge...
It could be written in lisp for sure to be fast enough - look at chlh_jd's example...
The problem is that complexity may grow - ultimate roofs - 100 and more vertices...
If you test it, you'll see what it do till now... The problem arises with widening code - finding correct solution based on offsetting...
