I know that one can host multiple WPF User Controls in an AutoCAD Palette, but I am not sure where to start in order to create a custom drawing tabs interface.
My initial thought was that an Event Monitor would create a new Tab, for each document opened (Tab Factory?), and populate the tab name by extracting the Document name.
A quick test, of setting the UserControl() to a height of 23, and width of Autosize, relegating the resultant Palette to:
*.DockEnabled = (DockSides)Convert.ToInt32(DockSides.Top) + Convert.ToInt32(DockSides.Bottom);
Sadly, did not do what I wanted.
** Edit - Am I doing with the code behind, what I should be doing with an XAML Style?
... Any tips on where to start reading, source code examples, etc.?
TIA
