I've noticed a weird problem with the Autoloader system.
I've installed the MgdDbg module which creates a bundle in the ApplicationPlugin map. When AutoCAD starts, the first time I get a Fatal Error, the next time I start AutoCAD, it runs well. Afther that I get a Fatal Error, then the next time not, and so on. It happens in 2012 and the 2013 version.
It is not only this application, I've seen this before with an application I wrote, I tried to load it with this new loading system, but after so many Fatal Errors I quit using this system.
This loading system creates a registry key in the Autoloader registry section pointing to the bundle. When AutoCAD starts, it creates keys in the Applications registry section. While closing AutoCAD, it removes the keys from the Applications section. That is the way it should work.
But, after the keys are placed in the Applications section, I get a Fatal error and the keys are not removed. The next time AutoCAD starts, it finds the keys and that result in loading the application normally. When I close AutoCAD, it removes the keys from the registry. When I start AutoCAD again, the keys are not there so they are placed by the Autoloader system and so I get the Fatal error again.
Is it some problem only I have? Is there someone else with this problem? I am not sure if placing keys in the registry is the problem or something else.
I installed AutoCAD 2013 which places a bundle map somewhere (might be an example?) and also that causes Fatal errors.
