Author Topic: Polyline tools  (Read 9037 times)
cadplayer
Polyline tools
« on: May 21, 2012, 08:24:39 AM »
Hi!
I find this thread to can extend polylines dynamically
http://autocadtips.wordpress.com/2011/10/19/lengthen-polyline-endpoint-vertex/
For me itīs pretty to much number of mouseclicks, so maybe it is here a function already to use ?!
Re: Polyline tools
« Reply #1 on: May 21, 2012, 09:09:30 AM »
I'm a little confused.
If you select the pline, grips appear. Pick the grip, it turns red and you are in stretch mode.
What more do you need?
I've reached the age where the happy hour is a nap. (°ŋ°)
cadplayer
Re: Polyline tools
« Reply #2 on: May 21, 2012, 09:23:02 AM »
Yes I think itīs little complicate. Normally you can use Autocad to extend a polyline:
1) marks grips run stretch mode
2) press B for Base point
3) marks grips 1times again
4) type in EXT and than you can dynamically change length
Iīm asking if itīs possible to can collect 4 steps in 1.
1) type command
2) select grips and than extend
You can take a look with command (command "lengthen" "dy") but it works only with lines. I look for same for polylines
alanjt
  • Standby for witty remark...
Dropbox
trogg
Re: Polyline tools
« Reply #4 on: May 21, 2012, 10:00:58 AM »
cadplayer
Re: Polyline tools
« Reply #5 on: May 21, 2012, 10:35:47 AM »
Thanks very good. Exactly what I want have.
irneb
Re: Polyline tools
« Reply #6 on: May 21, 2012, 10:50:24 AM »
Which version ACad are you using? My Vanilla 2012 works fine with the Lengthen command on polylines.
alanjt
Re: Polyline tools
« Reply #7 on: May 21, 2012, 10:52:51 AM »
Must have been introduced in 2012 - not in 2011.
Dropbox
cadplayer
Re: Polyline tools
« Reply #8 on: May 22, 2012, 02:10:41 AM »
I use Autocad C3D 2012 but can somebody explain me what is Vanilla 2012. I didnīt find explanation in Internet.
BlackBox
Re: Polyline tools
« Reply #9 on: May 22, 2012, 02:27:33 AM »
When someone uses "Vanilla" as a description in this context, they are describing the original "Plain," or "Basic" AutoCAD. This is common among many users of "Verticals" like Map, Civil 3D, etc. this is very common in English. Pun intended.
irneb
Re: Polyline tools
« Reply #10 on: May 22, 2012, 03:11:39 AM »
Yep, I always see it as "Vanilla ... like in ice-cream". I.e. the plain without frills.
alanjt
Re: Polyline tools
« Reply #11 on: May 22, 2012, 07:23:12 AM »
Except that, with ice-cream, Vanilla is not plain, it's vanilla flavored.  :-P
Dropbox
cadplayer
Re: Polyline tools
« Reply #12 on: May 22, 2012, 08:13:22 AM »
Think I right vanilla-cream is baseAutocad without any extensions as for example civil...? Why didnīt work lengthen also with polylines in civil?
irneb
Re: Polyline tools
« Reply #13 on: May 22, 2012, 08:37:36 AM »
Sorry, just reread the OP and the link. You're referring to Lengthen's Dynamic adjust - i.e. select then click new distance point. The other options seem to work on PL's, not the dynamic one.
cadplayer
Re: Polyline tools
« Reply #14 on: May 22, 2012, 09:18:29 AM »
Thanks. Amazing your animation it discribe fast what you want to say. I know itīs not a question in this thread but how have done it?
