Author Topic: Programmatically determine 'Isolate Objects State' (lamp icon)?  (Read 7061 times)
pedroantonio
Can I determine through vb.net if currentlly opened drawing contains Isolated objects (Isolated or Hidden)
which is in AutoCAD Environment visible through icon: bottom right lamp, color: red?
huiz
  • Certified Prof C3D
Re: Programmatically determine 'Isolate Objects State' (lamp icon)?
« Reply #1 on: May 19, 2012, 06:20:20 AM »
I'm not sure if there is a variable to see if there are hidden objects. But you can search the entities to see if there are entities with the property visible = false.
pedroantonio
« Reply #2 on: May 19, 2012, 06:42:00 AM »
But how the Autocad knows that?
I have just tested it and if I set some objects visible=false Autocad is smart enough to know that he is not doing it (the lamp stays yellow).
So i think that he sets some variable or counter to know when he (Autocad) has don that. Or not  :|
BlackBox
« Reply #3 on: May 19, 2012, 07:10:19 AM »
Methinks you are confusion the Entity Visible = False with freezing/turning off a layer.
« Reply #4 on: May 19, 2012, 07:19:49 AM »
Have a look in the Named Object Dictionary ..
Something like acad_objectisolation or somesuch.
huiz
« Reply #5 on: May 19, 2012, 07:34:28 AM »
Ah, I thought it was used for isolation. Did not test it though.
pedroantonio
« Reply #6 on: May 19, 2012, 02:27:46 PM »
Kerry thanks for this tip. Now after I see this dictionary: "ACAD_OBJECTISOLATION"
how to access this dictionary to read .count or something that will gave me a idea if isolated objects are in drawing?
« Reply #7 on: May 19, 2012, 08:00:35 PM »
This may get you started.
At this stage I don't know exactly what the returned ResultBuffer data means.
I think the first list reflects the instance count for the command when run consecutively ....
Code - C#: [Select]
  1.
  2. // (C) CodeHimBelonga Kdub@theSwamp 2012.05.20
  3. //
  4.
  5. using Autodesk.AutoCAD.ApplicationServices;
  6. using Autodesk.AutoCAD.DatabaseServices;
  7. using Autodesk.AutoCAD.EditorInput;
  8. using Autodesk.AutoCAD.Runtime;
  9. using AcadApp = Autodesk.AutoCAD.ApplicationServices.Application;
  10.
  11. [assembly: CommandClass(typeof (IsolateTest.MyCommands))]
  12.
  13. namespace IsolateTest
  14. {
  15.     public class MyCommands
  16.     {
  17.         [CommandMethod(globalName: "Doit", flags: CommandFlags.Modal)]
  18.         public void MyCommand()
  19.         {
  20.             Document doc = AcadApp.DocumentManager.MdiActiveDocument;
  21.             Database db  = doc.Database;
  22.             Editor ed    = doc.Editor;
  23.             const string KEY   = "ACAD_OBJECTISOLATION";
  24.
  25.             var data = new ResultBuffer();
  26.
  27.             using (Transaction tr = db.TransactionManager.StartTransaction())
  28.             {
  29.                 var nod =
  30.                     (DBDictionary) tr.GetObject(db.NamedObjectsDictionaryId, OpenMode.ForRead);
  31.
  32.                 if ((nod == null) || (!nod.Contains(KEY)))
  33.                 {
  34.                     ed.WriteMessage("\nNo Data attached to NOD");
  35.                     return;
  36.                 }
  37.
  38.                 var xrecord = (Xrecord) tr.GetObject(nod.GetAt(KEY), OpenMode.ForRead);
  39.
  40.                 data = xrecord.Data;
  41.
  42.                 tr.Commit();
  43.             }
  44.             ed.WriteMessage("\nData: " + data.ToString());
  45.         }
  46.     }
  47. }
  48.
Command:
Command: netload
Command: doit
Command:
Command:
Command: ISOLATEOBJECTS
Select objects: Specify opposite corner: 2 found
Select objects:
Command: doit
Data: ((70,0)(70,-1))
Command:
Command:
Command: UNISOLATEOBJECTS
1 object(s) unisolated.
Command:
Command:
Command: HIDEOBJECTS
Select objects: 1 found
Select objects: 1 found, 2 total
Select objects:
Command: doit
Data: ((70,2)(70,-1))
Command:
Command:
2 object(s) unisolated.
« Last Edit: May 19, 2012, 08:09:14 PM by Kerry »
BlackBox
« Reply #8 on: May 19, 2012, 10:13:20 PM »
Awesome, Kerry. :beer:
BTW - 'codehimbelonga' lmfao
pedroantonio
« Reply #9 on: May 20, 2012, 12:12:16 AM »
Thanks Kerry! This is better then a start. Now its rolling in right direction...
I'm trying it now... ;)
I will post back if I found something...
« Reply #10 on: May 20, 2012, 02:50:44 AM »
I just did a search for ACAD_OBJECTISOLATION on the ADN, hoping for some clarification of the return data.
No luck. Perhaps someone who knows the meaning of the ResultBuffer.Data returned will amble by.
Regards
gile
  • Marseille, France
« Reply #11 on: May 20, 2012, 06:21:05 AM »
By my side, using A2011 Vanilla, A2012 MEP or A2013 Vanilla, the ISOLATEOBJECTS and/or HIDEOBJECTS create a AEC_ISOLATED_OBJECTS dictionary containing a AEC_ISOLATED_OBJECTS_XRECORD xrecord.
If they're some hidden objects the xrecord contains these objects ObjectId (a (70, -1) TypedValue otherwise).
Code - C#: [Select]
  1. using Autodesk.AutoCAD.ApplicationServices;
  2. using Autodesk.AutoCAD.DatabaseServices;
  3. using Autodesk.AutoCAD.EditorInput;
  4. using Autodesk.AutoCAD.Runtime;
  5. using AcAp = Autodesk.AutoCAD.ApplicationServices.Application;
  6.
  7. namespace IsolatedObjectDictionary
  8. {
  9.     public class Commands
  10.     {
  11.         [CommandMethod("Test")]
  12.         public void Test()
  13.         {
  14.             Document doc = AcAp.DocumentManager.MdiActiveDocument;
  15.             Database db = doc.Database;
  16.             Editor ed = doc.Editor;
  17.             ObjectIdCollection hidden = GetHiddenObjects(db);
  18.             if (hidden.Count == 0)
  19.             {
  20.                 ed.WriteMessage("\nNone hidden object found");
  21.             }
  22.             else
  23.             {
  24.                 foreach (ObjectId id in hidden)
  25.                 {
  26.                     ed.WriteMessage("\nHidden entity: {0}", id.ObjectClass.Name);
  27.                 }
  28.             }
  29.         }
  30.
  31.         public ObjectIdCollection GetHiddenObjects(Database db)
  32.         {
  33.             ObjectIdCollection result = new ObjectIdCollection();
  34.             using (Transaction tr = db.TransactionManager.StartTransaction())
  35.             {
  36.                 DBDictionary NOD = (DBDictionary)tr.GetObject(db.NamedObjectsDictionaryId, OpenMode.ForRead);
  37.                 if (!NOD.Contains("AEC_ISOLATED_OBJECTS"))
  38.                 {
  39.                     return result;
  40.                 }
  41.                 DBDictionary dict = (DBDictionary)tr.GetObject((ObjectId)NOD["AEC_ISOLATED_OBJECTS"], OpenMode.ForRead);
  42.                 Xrecord xrec = (Xrecord)tr.GetObject((ObjectId)dict["AEC_ISOLATED_OBJECTS_XRECORD"], OpenMode.ForRead);
  43.                 foreach (TypedValue tv in xrec.Data)
  44.                 {
  45.                     if (tv.TypeCode == 340)
  46.                     {
  47.                         result.Add((ObjectId)tv.Value);
  48.                     }
  49.                 }
  50.                 return result;
  51.             }
  52.         }
  53.     }
  54. }
  55.
« Last Edit: May 20, 2012, 06:41:31 AM by gile »
pedroantonio
« Reply #12 on: May 21, 2012, 12:10:11 PM »
I am using acad 2011 vanilla and I dont have AEC_ISOLATED_OBJECTS or AEC_ISOLATED_OBJECTS_XRECORD :(
The only similar that I have is the one from previous post but i dont get it how could that help. It just shows that Isolated mode has been 1 or more times activated...
Any other ideas maybe  :?
MexicanCustard
« Reply #13 on: September 25, 2012, 01:07:22 PM »
Looks like using the ISOLATEOBJECTS command also puts AEC_ISOLATEDOBJECTS_XDATA in each objects XDATA.  Anyone know what for?
Jeff H
« Reply #14 on: September 25, 2012, 02:26:30 PM »
Would using a VisibilityOverrule with a counter incrementing and decrementing the count work?
Just a thought no idea if would work or if too much overhead.
