Author Topic: -={ Challenge }=- Doomsday Algorithm  (Read 12950 times)
« on: May 10, 2012, 07:25:35 PM »
The Challenge:
Write a function:
  1. (_getday YYYY MM DD)
Where:
YYYY = four digit year
  MM = month
  DD = day
To return the day of the week for the given date.
Example:
  1. (_getday 2012 5 11)
  2. "Friday"
« Last Edit: May 11, 2012, 06:13:46 AM by Lee Mac »
pBe
Re: -={ Challenge }=- Doomsday Algorithm
« Reply #1 on: May 11, 2012, 02:42:24 AM »
Does it have to be a unique algorithm and not like the known ones listed elsewhere?  :-D
« Reply #2 on: May 11, 2012, 03:27:06 AM »
Ok, this isn't the prettiest, but it is functional and I have included two variations to get the longday.
  1. (defun doomsday (yyyy mm dd)
  2.   ;;Calculate years for Julian Date
  3.   (setq y (+ yyyy
  4.              (if (< mm 3)
  5.                4799
  6.                4800
  7.              )
  8.           )
  9.
  10.   )
  11.   ;;Calculate days for Julian Date
  12.   (setq jdn (- (+ dd
  13.                   (fix (/ (+ (* 153
  14.                                 (if (< 2 mm)
  15.                                   (- mm 3)
  16.                                   (+ mm 9)
  17.                                 )
  18.                              )
  19.                              2
  20.                           )
  21.                           5
  22.                        )
  23.                   )
  24.                   (* 365 y)
  25.                   (fix (/ y 4))
  26.                   (fix (/ y 400))
  27.                )
  28.                (fix (/ y 100))
  29.                32045
  30.             )
  31.   )
  32.   ;;Day of the week is modulus(Julian 7)
  33.   ;;Monday = 0
  34.   (setq DDDD (rem jdn 7))
  35.   (cond
  36.     ((= DDDD 0)"Monday")
  37.     ((= DDDD 1)"Tuesday")
  38.     ((= DDDD 2)"Wednesday")
  39.     ((= DDDD 3)"Thursday")
  40.     ((= DDDD 4)"Friday")
  41.     ((= DDDD 5)"Saturday")
  42.     ((= DDDD 6)"Sunday")
  43.   )
  44.   ;;Another method to obtain the day of week using DIESEL
  45. ;;;(setq DDDD (menucmd (strcat "M=$(edtime," (rtos jdn 2 0) ",DDDD - M/DD/YYYY)")))
  46. ;;;DDDD
  47. )
« Reply #3 on: May 11, 2012, 06:03:49 AM »
If you can concoct a unique and original algorithm for the problem then post away!  8-)
Just a bit of fun, you can tackle the problem as you wish  :-)
« Reply #4 on: May 11, 2012, 06:05:37 AM »
Nice one Keith - I thought it likely someone may opt for the conversion to Julian over coding Conway's Doomsday Algorithm  :-)
BTW, good call on the separate arguments over a list - not sure what I was thinking there - I may alter the first post to reflect this.
« Last Edit: May 11, 2012, 06:12:22 AM by Lee Mac »
pBe
« Reply #5 on: May 11, 2012, 06:07:44 AM »
Not pretty at all.
  1. (defun _getday  (yrl mn dy / x m yrl)
  2.       (setq x  (vl-some
  3.                       '(lambda (x)
  4.                              (if (<= (caadr x) yrl (cadadr x))
  5.                                    x))
  6.                       (list '(4 (1700 1799))
  7.                             '(2 (1800 1899))
  8.                             '(0 (1900 1999))
  9.                             '(6 (2000 2099))
  10.                             '(4 (2100 2199))
  11.                             '(2 (2200 2299))
  12.                             '(0 (2300 2399))
  13.                             '(6 (2400 2499))
  14.                             '(4 (2500 2599))
  15.                             '(2 (2600 2699)))))
  16.       (setq m (append (if (zerop (+ (rem yrl 4)
  17.                                     (rem yrl 100)))
  18.                             (if (zerop (rem yrl 400))
  19.                                   '((1 6) (2 2))
  20.                                   '((1 0) (2 3)))
  21.                             '((1 6) (2 2)))
  22.                       '((3 3)
  23.                         (4 6)
  24.                         (5 1)
  25.                         (6 4)
  26.                         (7 6)
  27.                         (8 2)
  28.                         (9 5)
  29.                         (10 0)
  30.                         (11 3)
  31.                         (12 5))))
  32.
  33.       (nth (rem (+ (car x)
  34.                    (setq lt (- yrl (caadr x)))
  35.                    (/ lt 4)
  36.                    (cadr (assoc mn m))
  37.                    dy)
  38.                 7)
  39.            '("Sunday"
  40.              "Monday"
  41.              "Tuesday"
  42.              "Wednesday"
  43.              "Thursday"
  44.              "Friday"
  45.              "Saturday")))
Taken from
A tabular method to calculate the day of the week
EDIT: to follow new format  :-D ADJUSTED Leap Year
« Last Edit: May 11, 2012, 12:33:28 PM by pBe »
« Reply #6 on: May 11, 2012, 07:01:27 AM »
Implementing Zeller's congruence:
-- Incorrect code --  remains for thread continuity --
  1. (defun _getday ( y m d )
  2.     (if (< m 3) (setq y (1- y)))
  3.     (nth
  4.         (rem (+ d (/ (* 26 (1+ m)) 10) y (/ y 4) (* 6 (/ y 100)) (/ y 400)) 7)
  5.        '("Saturday" "Sunday" "Monday" "Tuesday" "Wednesday" "Thursday" "Friday")
  6.     )
  7. )
« Last Edit: May 11, 2012, 09:52:39 AM by Lee Mac »
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #7 on: May 11, 2012, 07:35:44 AM »
  1. (defun getday (y m d / a)
  2.   (setq y (- y (setq a (/ (- 14 m) 12))))
  3.   (nth (rem (+ 7001 d y (/ y 4) (/ y -100) (/ y 400) (/ (* 31 (+ m (* 12 a) -2)) 12)) 7)
  4.        '("Saturday" "Sunday" "Monday" "Tuesday" "Wednesday" "Thursday" "Friday")
  5.   )
  6. )
David Bethel
« Reply #8 on: May 11, 2012, 07:41:26 AM »
AutoCAD included julian.lsp ( 1988-1993 ) in it support folder that has CTOJ ( calender to Julian ) and JTOW ( julian to week ).  But it has all the DONT publish or distribute BS in it.  It is an interesting read though.  -David
PS  Mine has the limits :  This one doesn't seem to have the same :
http://www.andor.net/ftp/ftp1/Program_masters/ACAD/BONUS/CADTOOLS/julian.lsp
R12 Dos - A2K
« Reply #9 on: May 11, 2012, 07:42:13 AM »
  5.   )
  6. )
Another Julian conversion, nice one Evgeniy :-)
« Last Edit: May 11, 2012, 07:51:10 AM by Lee Mac »
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #10 on: May 11, 2012, 09:07:21 AM »
(setq y 1812 m 2 d 20)
(lee_getday y m d) = "Sunday"
(ee_getday y m d)  = "Tuesday"
(pBe_getday y m d)  = "Friday"
(keith_doomsday y m d)  = "Thursday"
« Last Edit: May 11, 2012, 09:15:23 AM by ElpanovEvgeniy »
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #11 on: May 11, 2012, 09:25:13 AM »
« Reply #12 on: May 11, 2012, 09:29:54 AM »
Oops!
http://www.wolframalpha.com/input/?i=20.02.1812
« Reply #13 on: May 11, 2012, 09:36:06 AM »
I forgot that the months are shifted back by two in the Zeller's congruence algorithm:
  1. (defun lm:getday ( y m d )
  2.    (if (< m 3) (setq y (1- y) m (+ m 12)))
  3.    (nth (rem (+ d (/ (* 26 (1+ m)) 10) y (/ y 4) (* 6 (/ y 100)) (/ y 400)) 7)
  5.    )
  6. )
  1. _$ (lm:getday 1812 2 20)
  2. "Thursday"
« Last Edit: May 11, 2012, 09:53:30 AM by Lee Mac »
pBe
« Reply #14 on: May 11, 2012, 09:37:09 AM »
Oops!
pBe is sooo BUSTED!  :-D
  1. (if (or (zerop (+ (rem yrl 4)
  2.                                         (rem yrl 100)))
  3.                               (zerop (rem yrl 400)))
  4.                             '((1 0) (2 3))'((1 6) (2 2)))
EDIT: oh bummer..
(pBe_getday 2000 1 1) "Sunday" <---
(LM_getday  2000 1 1) "Saturday" <----
(pBe_getday 2000 1 1) "Saturday <--- corrected
<<<pBe Needs an aspirin>>>  :-)
« Last Edit: May 11, 2012, 12:36:23 PM by pBe »
