Author Topic: redefining COPY command  (Read 1433 times)
Lupo76
« on: May 09, 2012, 07:53:51 AM »
Hello everyone,
I wrote the following function:
(defun undefine-command (cname)
   (if (getcname cname)
        (setvar "cmdecho" 0)
        (command "._UNDEFINE" cname)
(undefine-command "_copy")
(defun copynew ()
  (alert "This is a test")
  (command "_.copy")
(defun c:copia ( )
  (copynew)
(defun c:copy ( )
   (copynew)
(defun c:_copy ( )
   (copynew)
This function works quite well but does not behave exactly like the COPY command in AutoCAD.
In practice, missing the request:
Specify base point or [Displacement / mode] <Spostamento>:
I also tried
(command "_.copy" obj"" "_o" "_m")
and other attempts but I can never simulate the exact behavior of the original COPY command.  :cry:
Do you have any idea?
Thanks in advance
Re: redefining COPY command
« Reply #1 on: May 09, 2012, 09:16:19 AM »
What do you get with this?
(command "_.copy" obj "" pause)
