Author Topic: Standard DCL question?  (Read 25646 times)
Sam
Re: Standard DCL question?
« Reply #30 on: May 22, 2012, 08:45:59 AM »
What I was showing with the VPT command routine, was that the MPL can be applied to set the VPORT scale. In modelspace its global, with VPT it is view port specific.
Command: vpt
   ACAD & Custom linetypes are loaded with General Layers!!
Error - linetype load failed for SML-DASH2
#<%catch-all-apply-error%>
   Select first corner of window opening:
   Select opposite corner of window opening:
      Scale list being loaded, Please be patient......
16 scales added
 My Scale List Begins....
; error: no function definition: SET_TILE_LIST
Command:
Command: *Cancel*
Command: *Cancel*
Command: MPL
0 scales added
Every time we waste electricity, we put our planet's future in the dark. Let's turn around our attiude and start saving power and our planet, before it's too late
http://www.theswamp.org/donate.html
KewlToyZ
« Reply #31 on: May 23, 2012, 12:12:55 PM »
Ahh forgot about the custom line types.
And You don't seem to have the MPL.dcl file loading?
Sam
« Reply #32 on: May 24, 2012, 02:23:42 AM »
dear sir,
 same error again
Command: VPT
CMDECHO
Enter new value for CMDECHO <1>: 0
32 scales added
Command: *Cancel*
Command: *Cancel*
Command:   <Switching to: Model>
Restoring cached viewports.
Command: mpl
 mspace set.
0 scales added
one more attachments to be cont...
Sam
« Reply #33 on: May 24, 2012, 02:24:28 AM »
last attachments
KewlToyZ
« Reply #34 on: May 24, 2012, 09:15:28 AM »
dear sir,
 same error again
Command: VPT
CMDECHO
32 scales added
Command: *Cancel*
Command: *Cancel*
Command: mpl
 mspace set.
0 scales added
I cannot duplicate the SET_TILE_LIST error in 2012?
Are you using an annotative drawing template?
Annotative Scales could be preventing this from working.
KewlToyZ
« Reply #35 on: May 24, 2012, 09:38:36 AM »
Check these variables in your drawing for me.
(command "ANNOTATIVEDWG" 0)   ; Specifies whether or not the drawing will behave as an annotative block when inserted into another drawing - 0 = False
; 0    Nonannotative
; 1    Annotative
; Note   The ANNOTATIVEDWG system variable becomes read-only if the drawing contains annotative objects.
;  (princ "\n")
(command "ANNOAUTOSCALE" -4)
;   Updates annotative objects to support the annotation scale when the annotation scale is changed.
;   When the value is negative, the autoscale functionality is turned off, but the settings are maintained:
; 1   Adds the newly set annotation scale to annotative objects that support the current scale except for those on layers that are turned off, frozen, locked or that are set to Viewport > Freeze.
; -1    ANNOAUTOSCALE is turned off, but when turned back on is set to 1.
; 2   Adds the newly set annotation scale to annotative objects that support the current scale except for those on layers that are turned off, frozen, or that are set to Viewport > Freeze.
; -2    ANNOAUTOSCALE is turned off, but when turned back on is set to 2.
; 3   Adds the newly set annotation scale to annotative objects that support the current scale except for those on layers that are locked.
; -3   ANNOAUTOSCALE is turned off, but when turned back on is set to 3.
; 4   Adds the newly set annotation scale to all annotative objects that support the current scale.
; -4    ANNOAUTOSCALE is turned off, but when turned back on is set to 4.
(command "ANNOALLVISIBLE" 1)   ;   Hides or displays annotative objects that do not support the current annotation scale.
;   The ANNOALLVISIBLE setting is saved individually for model space and each layout.
;   Note   When ANNOALLVISIBLE is set to 1, annotative objects that support more than one scale will only display one scale representation.
;   0   Only annotative objects that support the current annotation scale are displayed
;   1    All annotative objects are displayed
Sam
« Reply #36 on: May 25, 2012, 06:13:23 AM »
; 0    Nonannotative
; 1    Annotative
;  (princ "\n")
dear sir
chk variables
Command: ANNOAUTOSCALE
Enter new value for ANNOAUTOSCALE <-4>: *Cancel*
Command: ANNOALLVISIBLE
Enter new value for ANNOALLVISIBLE <1>: *Cancel*
Command: ANNOTATIVEDWG
Enter new value for ANNOTATIVEDWG <0>: *Cancel*
« Last Edit: May 25, 2012, 06:18:57 AM by Sam »
