Author Topic: Could some one help me plz , create Stations  (Read 1075 times)
HasanCAD
« on: May 07, 2012, 09:30:41 am »
Hi all
a part of our work is drafting the shop drawing for PT (post tension) cable
what i am looking for is a lisp to draft the stations
- Pick pt1 and pt2
- Ask for c (low point) and L (high Point).
- Add the text as per the attached equation.
* All dim in mm
* Z direction should be ignored when picking the points
* (trans) should be considered in some cases the plan is rotated.
Thanks All
« Last Edit: May 08, 2012, 12:44:43 pm by CAB »
Re: Could some one help me plz
« Reply #1 on: May 07, 2012, 09:51:31 am »
I seem to remember a post some years ago dealing with a hanging chain.
Don't have time to look right now though.
Windows 7 core i7 870 2.93 12GB
irneb
  • ACad R9-2013, Revit Arch 6-2013
« Reply #2 on: May 08, 2012, 03:38:54 am »
HasanCAD
« Reply #3 on: May 08, 2012, 04:41:02 am »
Thanks CAD
Thanks irneb
I do not want to draft the curve I just want to draft the stations and text only in step 4
the elevation only for clarification
Let me show you a plan to imagine the time what I spending to calculate one by one.
Thanks again
« Reply #4 on: May 08, 2012, 09:54:39 am »
Hi all
- Pick pt1 and pt2
* All dim in mm
Thanks All
Does the profile object exist in the drawing?
If so just pick it for the information needed if it is to scale.
I guess you would need to input the top elevation.
HasanCAD
« Reply #5 on: May 08, 2012, 09:57:11 am »
No the profile not exist.
« Reply #6 on: May 08, 2012, 12:43:32 pm »
Here is a starting point for you.
(defun c:PTstations(/ p1 p2 step dist #pts ang idx)
  (if (and (setq p1 (getpoint "\nPick first point."))
           (setq p2 (getpoint "\nPick second point.")))
      (setq step 1000
            dist (distance p1 p2)
            #pts (fix (/ (/ dist step)2))
            ang  (angle p1 p2)
            idx  1
      (repeat #pts
        (command "_Point" "_non" (polar p1 ang (* idx step)))
        (command "_Point" "_non" (polar p2 ang (- (* idx step))))
        (setq idx (1+ idx))
HasanCAD
Re: Could some one help me plz , create Stations
« Reply #7 on: May 09, 2012, 03:32:03 am »
depending on the formula in the beginning, this is next step
but the code drafts one point only each side
(defun c:PTstations (/
     p1 p2 L c
     Xt Yt x a y
   (setq L (getreal  "\nWhat is low point? "))
   (setq c (getreal  "\nWhat is High point? "))
      (setq step 1000
            ang  (angle p1 p2)
            idx  1
      (repeat #pts
(setq Xt (/ dist 2)
      Yt (- l c)
      x (- Xt (* idx step))
      a (/ Yt (* Xt Xt))
      y (+ (* a (* x x)) c)
      yr (round y 5)
              ang  (angle p1 p2)
              idx  1
        (setq idx (1+ idx))
(defun round ( number by )
    ; http://www.theswamp.org/index.php?topic=3076.0;all
    (if (zerop by) number
        (+  (* (fix (/ number (setq by (abs by)))) by)
            (if (< (* 0.5 by) (rem number by)) by  0 )))
« Reply #8 on: May 09, 2012, 08:05:57 am »
Try this, see comments in code.
     p1 p2 L c
     Xt Yt x a y
      (setq step 1000
            ang  (angle p1 p2)
            idx  1
      (repeat #pts
(setq Xt (/ dist 2)
      Yt (- l c)
      a (/ Yt (* Xt Xt))
      yr (round y 5)
              ;;  these don't belong here
      ;; #pts (fix (/ (/ dist step)2))
              ;; ang  (angle p1 p2)
              ;; idx  1
        ;;  text height is 20, offset from line is 40
        (MakeText (rtos yr 2 0) (polar (polar p1 ang (* idx step)) (* pi 1.5) 40) "0" 20)
        (MakeText (rtos yr 2 0) (polar (polar p2 ang (- (* idx step))) (* pi 1.5) 40) "0" 20)
        (setq idx (1+ idx))
;;  pre set to Middle Center
(defun MakeText (str pt lyr ht)
  (entmakex (list (cons 0 "TEXT") ;***
                 (cons 1 str) ;* (the string itself)
                 (cons 6 "BYLAYER") ; Linetype name
                 (cons 7 "STANDARD") ;* Text style name, defaults to STANDARD, not current
                 (cons 8 lyr)   ; layer
                 (cons 10 pt) ;* First alignment point (in OCS)
                 (cons 11 pt) ;* Second alignment point (in OCS)
                 (cons 39 0.0) ; Thickness (optional; default = 0)
                 (cons 40 ht) ;* Text height
                 (cons 41 1.0) ; Relative X scale factor, Width Factor, defaults to 1.0
                 (cons 50 0.0) ; Text rotation ange
                 (cons 51 0.0) ; Oblique angle
                 (cons 62 256) ; color
                 (cons 71 0) ; Text generation flags
                 (cons 72 1) ; Horizontal text justification type
                 (cons 73 2) ; Vertical text justification type
                 (cons 210 (list 0.0 0.0 1.0)))))
Stefan
« Reply #9 on: May 10, 2012, 01:30:45 am »
This is a geometrical solution. First step only, because my results are different so I didn't go further.
  1. (defun c:parabola ( / p0 p1 p2 p3 p4 c L)
  2.  (if
  3.    (and
  4.      (setq p1 (getpoint "\nFirst point: "))
  5.      (setq p2 (getpoint p1 "\nSecond point: "))
  6.      (setq c (getdist "\nLowest level: "))
  7.      (setq L (getdist "\nHighest level: "))
  8.      (> (distance p1 p2) 0.0)
  9.    )
  10.     (progn
  11.       (setq p0 (polar
  12.                  (mapcar '(lambda (a b) (* 0.5 (+ a b))) p1 p2)
  13.                  (setq u (- (angle p1 p2) (* 0.5 pi)))
  14.                  (* 2.0 (- L c))
  15.                )
  16.             p3 (polar p1 u L)
  17.             p4 (polar p2 u L)
  18.       )
  19.       (entmake
  20.         (append
  21.           '((0 . "SPLINE")
  22.             (100 . "AcDbEntity")
  23.             (100 . "AcDbSpline")
  24.             (70 . 8)
  25.             (71 . 2)
  26.             (72 . 6)
  27.             (73 . 3)
  28.             (74 . 0)
  29.             (42 . 1.0e-10)
  30.             (43 . 1.0e-10)
  31.             (40 . 0.0)
  32.             (40 . 0.0)
  33.             (40 . 0.0)
  34.             (40 . 1.0)
  35.             (40 . 1.0)
  36.             (40 . 1.0)
  37.            )
  38.           (mapcar
  39.             '(lambda (x)
  40.                (cons 10 (trans x 1 0))
  41.              )
  42.             (list p1 p0 p2)
  43.           )
  44.         )
  45.       )
  46.       (entmake
  47.         (list
  48.           '(0 . "LINE")
  49.           (cons 10 (trans p3 1 0))
  50.           (cons 11 (trans p4 1 0))
  51.         )
  52.       )
  53.     )
  54.  )
  55.  (princ)
  56. )
The code above will give the same results as in attached picture, but they are different from yours.
Please check your calculus and tell me if I miss something.
HasanCAD
« Reply #10 on: May 13, 2012, 06:32:22 am »
You do not imagine how much time you saved.
Last step: This line please.
HasanCAD
« Reply #11 on: May 13, 2012, 07:14:01 am »
May be the result in attached not correct.
Any way, Only the plan is needed not the elevation, The elevation just of indication
Refer to the calculation, we have 2 types of calculations
- for one segment such as girder in bridges.
- for continuous tendons in slabs.
HasanCAD
« Reply #12 on: May 17, 2012, 04:52:03 am »
How to make text and line perpendicular on main line
This is code
;Main
(defun c:PTS (/ p1 p2 L c step dist #pts ang idx Xt Yt x a y)
   (setq L (getreal "\nWhat is High point? "))
   (setq c (getreal "\nWhat is Low point? "))
      (setq step 1000
    #pts (fix (/ (/ dist step) 2))
    ang (angle p1 p2)
    idx 1)
      (repeat #pts
(setq Xt (/ dist 2)
      Yt (- l c)
      a (/ Yt (* Xt Xt))
      yr (round y 5))
(MakeText
  (rtos yr 2 0)
  (polar (polar (trans p1 1 0) ang (* idx step)) (* pi 1.5) 400)
  "0"
  200)
(MakeLine
  (polar (polar (trans p1 1 0) ang (* idx step)) (* pi 1.5) 300)
  (polar (polar (trans p1 1 0) ang (* idx step)) (* pi 1.5) -300))
(MakeText
  (rtos yr 2 0)
  (polar (polar (trans p2 1 0) ang (- (* idx step))) (* pi 1.5) 400)
  "0"
  200
(MakeLine
  (polar (polar (trans p2 1 0) ang (- (* idx step))) (* pi 1.5) 300)
  (polar (polar (trans p2 1 0) ang (- (* idx step))) (* pi 1.5) -300)
(setq idx (1+ idx))
; Sub
(defun round (number by) ; http://www.theswamp.org/index.php?topic=3076.0;all
  (if (zerop by)
    number
by
0))))
;  CAB
(defun MakeLine (p1 p2)
  (entmakex (list (cons 0 "LINE")
  (cons 10 p1)
  (cons 11 p2))))
(princ "\n Type  PTS  to Invoke")
« Last Edit: May 17, 2012, 05:16:55 am by HasanCAD »
« Reply #13 on: May 17, 2012, 08:58:37 am »
Try this: You have to get the perpendicular angle as well as feed the "maketext" sub a rotation.
;Main
(defun c:pts (/ #pts a ang c dist idx l p1 p2 pang step x xt y yr yt)
   (setq p2 (getpoint p1 "\nPick second point."))
   (setq l (getreal "\nWhat is High point? "))
    (progn (setq step 1000
ang  (angle p1 p2)
pang (+ ang (/ pi 2.)) ;<<<---- RJP Added perpendicular angle
idx  1
   (repeat #pts
     (setq xt (/ dist 2)
   yt (- l c)
   x  (- xt (* idx step))
   a  (/ yt (* xt xt))
   yr (round y 5)
     (maketext (rtos yr 2 0)
       (polar (polar (trans p1 1 0) ang (* idx step)) (+ pi pang) 400)
       "0"
       200
       ang
     (makeline (polar (polar (trans p1 1 0) ang (* idx step)) pang 300)
       (polar (polar (trans p1 1 0) ang (* idx step)) pang -300)
       (polar (polar (trans p2 1 0) ang (- (* idx step))) (+ pi pang) 400)
       "0"
       200
       ang
     (makeline (polar (polar (trans p2 1 0) ang (- (* idx step))) pang 300)
       (polar (polar (trans p2 1 0) ang (- (* idx step))) pang -300)
     (setq idx (1+ idx))
; Sub
  (if (zerop by)
    number
by
0
;  CAB
(defun maketext (str pt lyr ht rot)
  (cons 50 rot) ; <<<----- RJP ADDED Text rotation angle
(defun makeline (p1 p2) (entmakex (list (cons 0 "LINE") (cons 10 p1) (cons 11 p2))))
AutoCAD 2014
Dell Optiplex 9010 / Intel I7-3770 / 8GB RAM / NVidia 550ti
HasanCAD
« Reply #14 on: May 20, 2012, 01:30:12 am »
Try this:
Thanks,
This is what I am looking for
