Author Topic: Object DCL 2013 Compatability?  (Read 4789 times)
KewlToyZ
« on: May 05, 2012, 10:52:31 PM »
I can't seem to get the latest download to work.
I wondered if it was because I use the MEP vertical or if it was not compatible with 2013 yet?
I didn't see anything about a new release since 2010 so I thought I would ask you folks.
Thanks.
Re: Object DCL 2013 Compatability?
« Reply #1 on: May 05, 2012, 11:17:09 PM »
7.0.0.4 was released late March and supports AutoCAD 2013.
I have no issues with Vanilla AutoCAD 2013.
Have you re-installed the MSI after installing 2013 ?
Is OpenDCL demand loading ie what happens when you enterOPENDCL at the command line.
If nothing, can you Appload the ARX  ?
C:\Program Files (x86)\Common Files\OpenDCL\.....
If so, can you Appload a sample ?
C:\Program Files (x86)\OpenDCL Studio\ENU\Samples\_MasterDemo.lsp
From the Desktop, when you run the Editor :: From the Menu Select Help->About OpenDCL ... does the dialog display build no. 7.0.0.4 ??
Regards
KewlToyZ
« Reply #2 on: May 06, 2012, 03:29:03 PM »
Thanks Kerry I'll double check.
