I made one correction to the routine & added some comments at the new file output code.
This table should explain how my code works.
My output does match the formatting of the OLD file.
(defun c:cnvdata (/ alllines fn oldfname newfname ln x newlines
ADDLIST ADD_WT DATA_LIST F I LST MINUS_LIST MINUS_N
MINUS_WT MIN_WT N NEW_WT OLD_WT WT WT_LIST)
(setq oldfname "d:/old.DAT")
(setq newfname "d:/new.DAT")
(defun sparsers (str delim / ptr lst) ; CAB
(while (setq ptr (vl-string-search delim str))
(setq lst (cons (substr str 1 ptr) lst))
(setq str (substr str (+ ptr 2)))
(reverse (cons str lst))
;; CAB 02/09/06 - Pad Left side of string with spaces
(defun padR (word len / spaces)
(repeat (- len (strlen word)) (setq spaces (cons 32 spaces)))
(strcat word (vl-list->string spaces))
(defun padL (word len / spaces)
(strcat (vl-list->string spaces) word)
(defun MakeNum (lst) ; convert items 5, 9, 10 to numbers
(list
(car lst)
(cadr lst)
(caddr lst)
(cadddr lst)
(nth 4 lst)
(atoi (nth 5 lst))
(nth 6 lst)
(nth 7 lst)
(nth 8 lst)
(atof (nth 9 lst))
(atof (nth 10 lst))
(if (and (setq fn (findfile oldfname))
(setq fn (open fn "r"))
(princ "\nData file open success!\n")
(while (setq ln (read-line fn)) ; read all the lines in the file
(setq alllines (cons ln alllines))
(close fn) ; close the open file handle
(foreach ln alllines
(setq lst (vl-remove "" (sparsers ln " ")))
((= (length lst) 10) ; add 3rd item
(setq data_list (cons (makeNum (append (list (car lst)(cadr lst) " ") (cddr lst))) data_list))
((= (length lst) 3)(setq data_list (cons lst data_list)))
((setq data_list (cons (makeNum lst) data_list)))
(setq n (length data_list))
(setq wt_list (nth (- n 1) data_list))
(setq old_wt (atof (nth 2 wt_list))) ; get 3rd item
(setq new_wt (* old_wt 1.05))
(setq wt old_wt)
(setq min_wt (* old_wt 0.001))
(setq i 1)
(while (> (abs (- wt new_wt)) min_wt)
(setq minus_list (nth i data_list))
(setq minus_n (nth 5 minus_list))
(if (> minus_n 1)
(setq addlist (nth (+ i 1) data_list))
(setq minus_wt (nth 9 minus_list))
(setq add_wt (nth 9 addlist))
(setq wt (cal "wt - minus_wt + add_wt"))
(setq minus_list
(list
(nth 0 minus_list)
(nth 1 minus_list)
(nth 2 minus_list)
(nth 3 minus_list)
(nth 4 minus_list)
(- minus_n 1)
(nth 6 minus_list)
(nth 7 minus_list)
(nth 8 minus_list)
minus_wt
(- (nth 10 minus_list) minus_wt)
(setq data_list (subst minus_list (nth i data_list) data_list))
(setq addlist
(list
(nth 0 addlist)
(nth 1 addlist)
(nth 2 addlist)
(nth 3 addlist)
(nth 4 addlist)
(+ (nth 5 addlist) 1)
(nth 6 addlist)
(nth 7 addlist)
(nth 8 addlist)
add_wt
(+ (nth 10 addlist) add_wt)
(setq data_list (subst addlist (nth (+ i 1) data_list) data_list))
(setq i (+ i 1))
(if (= i (- n 2))
(setq i 1)
(setq data_list (subst (subst wt old_wt wt_list) wt_list data_list))
(princ (if (setq fn (open "d:/new.DAT" "w"))
"Data file open success!\n"
"Data files can't open!\n"
(foreach record data_list
((= (length record) 11)
(princ (padL (car record) 4) fn) ; col 1, RIGHT justify 4 charcters wide
(princ " " fn) ; 4 spaces
(princ (padR (cadr record) 7) fn) ; col 2, LEFT justify 7 charcters wide
(princ (padR (caddr record) 11) fn) ; col 3, LEFT justify 11 charcters wide
(princ (cadddr record) fn) ; col 4, no change 4 charcters wide
(princ " " fn) ; 2 spaces
(princ (nth 4 record) fn) ; col 5, no change 4 charcters wide
(princ (padL (itoa(nth 5 record)) 6) fn) ; col 6, RIGHT justify 6 charcters wide
(princ (nth 6 record) fn) ; col 7, no change 3 charcters wide
(princ (nth 7 record) fn) ; col 8, no change 5 charcters wide
(If (vl-string-search "/" (nth 8 record))
(princ (padL (nth 8 record) 12) fn) ; col 9, RIGHT justify 12 charcters wide
(princ (padL (strcat(nth 8 record)" ") 12) fn) ; col 9, RIGHT justify 12 charcters wide
(princ (padL (rtos(nth 9 record)2 2) 8) fn) ; col 10, RIGHT justify 6 charcters wide
(princ (padL (rtos(nth 10 record)2 1) 9) fn) ; col 11, RIGHT justify 9 charcters wide
(; print the last line in the file
(princ (padL (car record) 2) fn) ; RIGHT justify 2 characters wide
(princ (padL (cadr record) 40) fn) ; RIGHT justify 40 characters wide
(princ (padL (caddr record) 41) fn) ; RIGHT justify 40 characters wide
(princ "\n" fn)
(close fn)
) ; progn
(princ "\nData files can't open!\n")
) ; Endif
) ; end defun
