Author Topic: Insert multiple drawings as blocks in array  (Read 684 times)
cangelo3d
  • Mosquito
« on: May 01, 2012, 06:08:03 am »
I am totally new to vba programming and unfortunately i have problem sorting out basic things.
What i want to achieve:
user sets amount of times each block is to be inserted,
user picks a point for block1,
system creates an array of one row and i numbers of columns (i=defined by the user in previous step)
user picks a point for block2,
and so on...
anyone has any suggestions on how to procced?
anything would be much appreciated!
(i am running vba through autocad 2012)
fixo
  • Pietari, Venäjä
Re: Insert multiple drawings as blocks in array
« Reply #1 on: May 01, 2012, 11:10:07 pm »
See MinsertBlock method in the Help file:
Option Explicit
Public Sub TestForBlockArray()
Dim acsp As AcadBlock
Set acsp = ThisDrawing.ActiveLayout.Block
Dim pt(2) As Double
Dim blkname  As String
Dim NumRows As Long, _
NumColumns As Long, _
RowSpacing As Long, _
ColumnSpacing As Long
NumRows = 24
NumColumns = 12
RowSpacing = 700
ColumnSpacing = 350
blkname="foo"    '<-- block name
acsp.AddMInsertBlock pt, blkname, 1, 1, 1, 0, NumRows, NumColumns, RowSpacing, ColumnSpacing
~'J'~
\\\"Always drink upstream from the herd."\\\ - Will Rogers, was died in 1935 plane crash
--> Donate to TheSwamp <--
BlackBox
« Reply #2 on: May 02, 2012, 12:23:41 am »
« Last Edit: May 02, 2012, 12:28:18 am by RenderMan »
"Potential has a shelf life." - Margaret Atwood
