Author Topic: always englsih command input  (Read 4122 times)
dussla
« on: May 08, 2012, 04:29:43 AM »
i am korean
in my work , all command is englsih
but after making new layer name , i foget to change english kebyoard button in many times
so i would like to  make always english  command input lsp
can you understand  my words ?
like this  http://www.cadtutor.net/forum/showthread.php?66262-wanted-vb-code-to-vlisp-migration
but work not ~ erromessage : user32.dll loadkeyboardlayout (00000409 1) excute erro
« Last Edit: May 08, 2012, 05:55:07 AM by dussla »
dussla
Re: always englsih command input
« Reply #1 on: May 09, 2012, 12:22:46 AM »
i found this  but  i have to change vlisp lang
help me pls
Option Explicit
Private Declare Function SystemParametersInfo Lib "user32" Alias "SystemParametersInfoA" (ByVal uAction As Long, ByVal uParam As Long, ByRef lpvParam As Any, ByVal fuWinIni As Long) As Long
Private Declare Function ActivateKeyboardLayout Lib "user32" ( _
ByVal HKL As Long, _
ByVal Flags As Long) As Long
Private Declare Function GetKeyboardLayout Lib "user32" ( _
ByVal dwLayout As Long) As Long
Private Declare Function GetKeyboardLayoutName Lib "user32" Alias "GetKeyboardLayoutNameA" ( _
ByVal pwszKLID As String) As Long
Private Const SPIF_SENDWININICHANGE = &H2
Private Const SPI_SETDEFAULTINPUTLANG = 90
Const HKL = "00000409"
Private Sub Command1_Click()
Dim retval As Long
retval = SystemParametersInfo(SPI_SETDEFAULTINPUTLANG, 0, HKL, SPIF_SENDWININICHANGE)
ActivateKeyboardLayout retval, 0
End Sub
irneb
« Reply #2 on: May 14, 2012, 08:25:30 AM »
AutoLisp does not have a way to link to external DLL functions. The only thing you can use is ActiveX/COM interfaces.
Perhaps try this: http://translate.google.co.za/translate?hl=en&sl=auto&tl=en&u=http%3A%2F%2Fwww.script-coding.com%2Fdynwrap.html
At the bottom of that page is an example of using the user32.dll --> ActiveKeyboardLayout through an ActiveX call to DynWrap.
