Hello everyone,
I thank you for the answers.
Sorry if I answer only now, m I had major problems connecting to the internet
Unfortunately, maybe I was not clear enough.
I read from an external txt file out dates expressed in number of seconds since 01.01.1970, so I have some numbers that may be 1000 or 1656, or 56541, etc..
Now I need to convert these numbers into a date expressed in any way (eg 14/05/2012 or "5/14/2012 | 12:55" etc..)
The solution (menucmd "M = $ (edtime, $ (getvar, date), MO-DD-YYYY)") suggested by RenderMan is fine, but I could not figure out you can replace s (getvar, date) with a number : I tried but it does not work.
I navigated through the other links that you have mentioned but none of these gave the solution to my problem.
Do you have any idea?
