Author Topic: Using variables from one routine in another?  (Read 1873 times)
stusic
« on: April 25, 2012, 09:31:19 AM »
Good morning!
I've got one more problem that's been bothering me for a while now.
I've got two routines, one that lists attributes values from a user-selected block, and one that sends an email. They both work perfectly by themselves.
I know the first one is from Lee Mac, but I don't know who to give credit to for the second. I wish I did, 'cause its awesome.
The problem I'm having is getting the list of attribute values from the first routine into the body of the email of the second routine. It looks simple enough, but for the life of me cannot get it to work. A second set of eyes may be able to point out the error of my ways.
Any help would be greatly appreciated; this has been bothering me for a while now. TIA!
The first bit of code:
(defun vl-GetAttributes ( block )
    (mapcar
        (function
            (lambda ( attrib )
                (cons (vla-get-TagString attrib) (vla-get-TextString attrib))
        (vlax-invoke block 'GetAttributes)
  (defun test (/ ss )
    (if (setq ss (ssget "_+.:E:S" '((0 . "INSERT") (66 . 1))))
        (princ (vl-GetAttributes (vlax-ename->vla-object (ssname ss 0))))
Second bit of code:
(defun c:CreateMail ()
; Who's going to get the mail
  (setq recipients_list (list "recipient@company.com"))
; What is the subject
  (setq subject "Subject of the mail")
; What is the body
  (setq body "Body of email")
; What are the attachments
  (setq attachments_list (list "MyDrawing.dwg"))
  (create-email
    recipients_list subject body attachments_list 1)
; Do send this mail immediately ;
  (create-email
    recipients_list subject body attachments_list 0)
; Do not yet send this mail
(defun create-email (recipients_list   subject
     email_send        /
     acadapp        acaddoc
     outlookapp        mail_object
     recipients_collection
     attachments_collection
     temp        ret
     item        cadz3d_function
  ;; Load the extended AutoLISP functions and ActiveX support
  ;; Get the application and current document objects
  (setq acadapp (vlax-get-acad-object)
acaddoc (vlax-get-property acadapp 'activedocument)
  ;; Get the existing outlook application object
  (if (or (= (setq outlookapp
    (vl-catch-all-apply
      'vlax-get-object
      (list "Outlook.Application")
     nil
  (/= (type outlookapp) 'vla-object)
    (progn (alert (strcat
    "Microsoft Outlook must already be running\n"
    "to create and send the email. This will be\n"
    "improved in future versions.\n\n"
    "Please start Microsoft Outlook and then close\n"
    "this dialog box to create the email.")
   (setq outlookapp
  (vl-catch-all-apply
    'vlax-get-object
  (if (= (type outlookapp) 'vla-object)
      ;; Create new email object
      (setq mail_object (vlax-invoke-method outlookapp 'createitem 0))
;; Get the recipients collection
(setq recipients_collection
(vlax-get-property
  mail_object
  'recipients
    ;; Add the recipients properties to the email
    (foreach item recipients_list
      (if (= (type item) 'str)
(vlax-invoke-method recipients_collection 'add item)
    ;; Add the subject properties to the email
    (if (= (type subject) 'str)
      (vlax-put-property mail_object 'subject subject)
    ;; Add the body properties to the email
    (if (= (type body) 'str)
      (vlax-put-property mail_object 'body body)
    ;; Add the attachements properties to the email
    (if (and (vl-consp attachments_list)
     (setq attachments_collection
    (vlax-get-property
      mail_object
      'attachments
      (foreach item attachments_list
  (and (setq temp (findfile item)) (vl-file-systime temp))
   (vlax-invoke-method attachments_collection 'add temp)
    ;; If the email_send equals 1 and the recipients_list, subject, and body were passed to the
    ;; function then send the email, otherwise display the email for the user to finish
    (if (and (= email_send 1)
     (vl-consp recipients_list)
     subject
     body
     (/= subject "")
     (/= body "")
      (vlax-invoke-method mail_object 'send)
      (vlax-invoke-method mail_object 'display)
    (setq ret t)
  (princ
    "\nCould not get the recipients collection from the new mail item"
       (princ "\nCould not create a new mail item through Outlook")
    (princ "\nCould not create a new instance of Outlook")
  ;; Release the objects
  (if (and (= (type attachments_collection) 'vla-object)
   (= (vlax-object-released-p attachments_collection) nil)
    (vlax-release-object attachments_collection)
  (if (and (= (type recipients_collection) 'vla-object)
   (= (vlax-object-released-p recipients_collection) nil)
    (vlax-release-object recipients_collection)
  (if (and (= (type mail_object) 'vla-object)
   (= (vlax-object-released-p mail_object) nil)
    (vlax-release-object mail_object)
  (if (and (= (type outlookapp) 'vla-object)
   (= (vlax-object-released-p outlookapp) nil)
    (vlax-release-object outlookapp)
  (if (and (= (type acaddoc) 'vla-object)
   (= (vlax-object-released-p acaddoc) nil)
    (vlax-release-object acaddoc)
  (if (and (= (type acadapp) 'vla-object)
   (= (vlax-object-released-p acadapp) nil)
    (vlax-release-object acadapp)
  ret
BlackBox
Re: Using variables from one routine in another?
« Reply #1 on: April 25, 2012, 10:15:57 AM »
I wouldn't write it this way in a routine, but as a quick example, consider this:
  1. ;; <snip>
  2.
  3. ;; What is the body
  4. ;;(setq body "Body of email")
  5. (setq body
  6.          (vl-princ-to-string
  7.            (vl-GetAttributes
  8.              (vlax-ename->vla-object
  9.                (ssname (ssget "_+.:E:S" '((0 . "INSERT") (66 . 1)))
  10.                        0)))))
  11.
  12. ;; <snip>
  13.
stusic
« Reply #2 on: April 25, 2012, 10:43:29 AM »
You might not write it like this, but I just did.
PS: Why not? Seems fine to me...
BlackBox
« Reply #3 on: April 25, 2012, 10:46:20 AM »
You're welcome.... Consider  body = nil   :wink:
« Reply #4 on: April 25, 2012, 10:49:17 AM »
You might want to peruse this thread as well for ideas:
http://www.theswamp.org/index.php?topic=37663.msg457229#msg457229
