Author Topic: Color lineweight settings for ctb  (Read 1510 times)
Jeff H
« on: April 24, 2012, 03:31:18 pm »
Wondering if anyone wanted to share what lineweights you use and ask a couple of questions.
How many different lineweights do you put in a single drawing?
When you use a architects floorplan for the background do you put it on a very thin lineweight and or screening(usually see 8 used)?
As for setting one up and trying to keep it simple was wanting some suggestions.
I might of got the idea from here but could not find the post.
Looking at the pic below
The color number increases by 10 left to right in each row.
The numbers to left are the last number in each color for that row.
So to use 4 four basic groups Fine, Thin, Medium, Thick
Then do something like all colors that ends with 0 is a Fine, The row that ends with 2 is Thin, 4 is medium etc....
And maybe for a range of each group - Let all colors that end in 1 be Fine at the smallest value and all numbers that end in 0 be Fine at the heaviest value
0=.18, 1=.15
2=.25, 3=.20
4=.35, 5=.30
etc......
dgorsman
Re: Color lineweight settings for ctb
« Reply #1 on: April 24, 2012, 04:02:23 pm »
I try to use three lineweights for reduced size prints (thin, medium, thick), and four to five lineweights for full-size prints (thin, medium-thin, medium thick, thick).
There isn't much organization for now, in the past it was almost like somebody threw a handful of darts at the color table but I've moved that forward a bit.  For 3D models and derived elevation/plan drawings named colors (e.g. GREEN RED MAGENTA) for annotations and general lines, and numbered colors (e.g. 9 - 249) for 3D objects/object lines which all plot the same weight (different disciplines can choose pretty much any colors they want and still get the same result).  Numbered colors 250 - 254 plot a progressive combination of half/quarter tone at thin/thick weight.  For schematic type drawings (e.g. P&IDs) its named colors for everything.
Trying to group colors gets a little difficult, as the colors at the outside edges are too dark for common use plus many of the colors are too close together to pick out differences.  The way I figure it there's around a dozen "unique" colors that can be pulled out of the numbered colors area if you don't duplicate the ACI hard-equivalent of the named colors.
I'm slowly walking everybody towards a few basic concepts e.g. text being a separate color from lines, colors from the same grouping behaving in similar ways, etc.  Due to tight scheduling, multiple projects having different schedules, and different supervisors wanting different things making *any* changes is like herding cats through a catnip farm.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
« Reply #2 on: April 24, 2012, 04:48:36 pm »
OMG quit using ctb  :-o
Windows 7 core i7 870 2.93 12GB
Jeff H
« Reply #3 on: April 24, 2012, 04:54:15 pm »
OMG I never thought you were the type that would say OMG! :D
No problem with stb but do you ever find difficult to tell what your plot will look like by just looking at the drawing?
« Reply #4 on: April 24, 2012, 05:08:50 pm »
I just do a plot preview.  :-)
It's just the fact that you're tied to colors for line weights except for overrides & pline widths.
Just easy to assign a plot style to a layer and forget it.
Play style names line VeryFine Fine Light Medium Heavy VeryHeavy or maybe you like Med30 Med35 Med40.
Sorry to be so abrupt but I have a thing about color styles.
Jeff H
« Reply #5 on: April 24, 2012, 05:19:23 pm »
I think we might try stb's,
but was more wondering for example what weight do you use for 1/8" text, or new devices vs existing devices?
For floorplan background?
danallen
« Reply #6 on: April 24, 2012, 05:53:54 pm »
I like to know the colors on the screen match the lineweight (WYSIWYG). I could use STBs, but then I have to check both the color and lineweight setting are in sync.
Dan
hmspe
« Reply #7 on: April 24, 2012, 07:30:12 pm »
100% CTB here.  Magenta is .70mm.  Everything else from color 1 to 14 is .35mm.  15 to 239 and 250 to 255 are .25mm.  239 uses object line weight (for title blocks that don't work well with my standard pens).  240 and 241 are .13mm.  242 through 249 are .09mm.  8, 9, and 250 to 255 print by the color number.  Everything else from 1 to 14 and 240 to 249 prints black.  From 15 to 239 print 55% screened.
Less than 5% of my clients use STB.  I convert everything I get to my color scheme.  The colors I use are to make it easy for me -- walls are color 82, ceiling grid 142, FF&E 54.  My symbols are cyan and magenta.
Works well for me.  YMMV.
“Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live.” -– Martin Golding
StykFacE
« Reply #8 on: April 24, 2012, 07:43:17 pm »
CTB's.... ugh, man it's things like this that make me discourage AutoCAD more and more and reminds me of how great Revit can be. BTW, STB's are the shiznits and I love them. I wiiiiiish my company would adopt them as our standard.
I like having a "copied" Profile with my PSpace set to White. I have a few extra templates that have the PSpace Layouts set to "Display Plot Styles" then I turn LWT to ON. This gives me a nice feel when I'm touching up the sheets file. Almost makes you feel like you're in Revit. NOT!!! But still, I notice myself leaving these settings on more and more nowadays. I guess Revit has rubbed off on me. But if you're worried about Lineweights, this is a good tip IMHO.
  • Mesozoic Relic
« Reply #9 on: April 24, 2012, 07:47:13 pm »
Doesn't vary much ...
I use the colour numbers above 11 mainly for modelling ..
Unless details are complicated I use colour numbers under 11 for details ... but I'm NOT an architect :)
This block has been on my titleblocks for more years than I really care to remember ...
added to translate:
the listing is [colour no.] and the OLD METRIC Rotring Pen size used on an A1 drawing
... the actual line weights I use are slightly less when printing to A3 paper ( which is normally the case )
« Last Edit: April 24, 2012, 07:54:00 pm by Kerry »
Discipline : absolutely none at all.
--> Donate to TheSwamp <--
BlackBox
« Reply #10 on: April 24, 2012, 07:53:09 pm »
See and I can't stand layouts that have a page setup that shows the plot... I work in CAD, while in cad I want to see my drawings in color. I work in paper space through viewports (once a drawing is setup), and if I want to see it in BW, either plot preview or send to PDF. Lemon squeezy.
Oh, and long live CTB, let the holy war continue! :lol:
FWIW - we are testing STB, I'm just not won over yet; still getting used to NCS mallarchy. LoL
"Potential has a shelf life." - Margaret Atwood
jonesy
« Reply #11 on: April 25, 2012, 06:25:35 am »
Our pen tables typically mimic the old drawing pens... eg white = 0.25mm pen width
As we often have to use client standards, we find that it does seem to vary from client to client.
There are so many people out there who will tell you "You Can't".... what you have to do is turn it around and say"Watch Me!"
www.travelthrutime.com
StykFacE
« Reply #12 on: April 25, 2012, 08:17:08 am »
RenderMan, take a second to think about STB's. Instead of keeping track of 256 colors and what lineweights are associated with that "color", you just apply a lineweight to whatever color you want. In other words, color no longer matters. You like dim layers in green, someone else in red... Who cares with STB but man... Heaven forbid a CTB gets in on that mix and you'll see a world of hurt if the lineweights differ by a large margin between green and red.
Also, masking is phenomenal with STB's. Just create a style and name it "Mask" or whatever, then set the screening to 0%. Now you have instant masking - no more wipeouts, no more locked into True Color 255,255,255. There are huge benefits to STB's and personally, I wish Autodesk would get rid of CTB's. Sure, some old schooler's would be biznatching for a while but they'll soon realize how much better and more powerful STB's are.
Oh and another thing, I think STB's get embedded into the file so when you send files to outside parties they're still there, correct? I've never attempted it but I have purged STB styles from outside CAD files so I assume. If this is confirmed then that's another benefit.
Just my $0.02 is all.  :kewl:
BlackBox
« Reply #13 on: April 25, 2012, 09:26:54 am »
I agree with you, and in a world where only what we wanted to do internally mattered STB's would be the way to go....
However, you neglect to consider those of us whom work predominantly using client-specific CAD Standards, as we do (in my new group). Most municipalities, have their own CAD Standards which... well... aren't exactly on the cutting edge, thus I must consider how best to leverage the technology with which I work, to meet or exceed my client's requirements.
Just in the past 60 days, I've received 5 client's CAD Standards, all of which vary in completeness, and consistency which prompted this thread... Now, consider not just STB, but having to setup Civil 3D Styles (all of them), for each_and_every_client on the fly.  :lol:
« Reply #14 on: April 25, 2012, 09:45:14 am »
Not likely that you are going to change your client's old habits but I thought the question was about setting up your "In House" standards.
Why not move to the modern method?  8-)
