Author Topic: (command "Hatch") Ribbon problem Acad 2011  (Read 1743 times)
NirantarVidyarthee
« on: April 23, 2012, 02:22:46 AM »
I want to start my own hatch command. (AutoCAD 2011)
In that, I want user to create the hatch manually and then process the hatch object created by the user in my command.
Manually, when you type hatch command at the command prompt:
"When the ribbon is active, the Hatch Creation contextual tab is displayed. When the ribbon is off, the Hatch and Gradient dialog box is displayed." (from Acad help).
However the (command "hatch") statement does not activate the contextual tab even when the ribbon is active.
I have tested all combinations with -hatch, -bhatch, cmddia and PAUSE, but without success.
Is this 'incomplete'  work by AutoCAD Development team?
I there a way to activate the contextual tab using Lisp after (command "xxx") statement?
I have searched the forum but could not find anything related.
Please help.
Re: (command "Hatch") Ribbon problem Acad 2011
« Reply #1 on: April 23, 2012, 06:08:32 AM »
Maybe this will help.  :-)
