Author Topic: BatchWORX  (Read 15725 times)
TimSpangler
  • CAD Naked!!
BatchWORX
« on: April 20, 2012, 02:57:40 PM »
As promised, here is a Batch Processing utility that I have been working on for a while (several failed attempts).  I have included some documentation to help explain a little bit about how to set it up and how it works.  This is a LISP only processor, it does not rely on scripts or lisp that create scripts, etc.  It utilizes the registry along with some code in the Batchworx.lsp to run when loaded.  I have been using this for about 6 months and it has held up nicely to my testing.  I would now like to get others to test it to exspose the bugs.  I have read just about everything there is to read online about batch processing, alot of what I tried was cumbersome or hard to follow or just plain complicated.  I wanted something that was easy to implement and easy to use.
The Batchworx adds a "load" line to the Acaddoc.lsp file to load the Batchworx.lsp for each dwg.
Code inside the Batchworx.lsp checks for certian parameters when loaded.  If those parameters are met, it then loads/ executes the selected process. If the parameters are not met, the drawing loads normally. (this is checked with every dwg that is opened, this is what allows for the batch processing).
When Batchworx is executed is sets a flag in the registry to T (this turns on Batch Processing. This is one parameter that is checked)
The user will then select a batch process to run (this parameter is set in the registry so that every dwg opened now knows what process to run)
The user then selects the dwg's to process. (they can be  in multiple directories/ locations).
This list of drawings are then opened. As each drawing is opened the parameters tell the drawing which process to load.  That process is loaded and executed. The process then closes the drawing and the next one is opened, etc.
Once the last drawing is opened Batchworx opens its own dwg (Batchworx.dwg it is an empty dwg). This drawing is a trigger to turn off the Batch process and clear the parameters from the registry.
Batchworx also has the ability to run a seperate process once the batch has ended.  This can be used to create a log and open it once completed, it can be used to reset varaibles, map network drives, etc (anything you need it to do).  This cleanup process can be a .vbs, .lsp, .bat, .exe. This can be expaned to include just about anything.  There is more of an explianation in the documentation.
I have included a sample batch file that creates a log file and opens that log upon completion.
I welcome any positive feedback.  The code is still abit "dirty" so keep that in mind.  If anyone has any question feel free to ask.
*NOTICE*
Batchworx adds a line to the acaddoc.lsp as well a creating some registry entries under "HKEY_CURRENT_USER\\Software\\BatchWORX"
[EDIT]  Replaced the attachment with current files.
« Last Edit: May 30, 2012, 07:49:52 AM by TimSpangler »
ACA 2015 - Windows 7 Pro
irneb
Re: BatchWORX
« Reply #1 on: April 21, 2012, 09:04:54 AM »
Great work! I was thinking along the same lines, just didn't have the time. BTW, my idea was to save a list of drawings to be opened into a registry folder. The loader would then check if the current DWG is one of them in that folder, if so - then run the script/lsp/etc. and delete that value out of the folder, then close the DWG and open the 1st one in the reg folder.
Was there a reason you didn't go that route and rather used a marker Batchworx.DWG file?
TimSpangler
  • CAD Naked!!
Re: BatchWORX
« Reply #2 on: April 21, 2012, 07:00:15 PM »
One of my failed attempts was saving the list to the registry.  That could potentially be a large list and I ran into trouble with that approach.  The batch sometimes stopped for no reason.  I think the better option would be to hold the number of dwg's, then as each dwg was processed -1 that number until it was 0.  That is one thing I am getting ready to test.
Did everything work as it was supposed to?  Is there anything that could make it more user friendly?
TimSpangler
  • CAD Naked!!
Re: BatchWORX
« Reply #3 on: April 24, 2012, 07:15:39 PM »
I tried using a counter set in the registry.  It worked for counting but once it was finished the process ended without cleaning up.
After looking at what is happening I realized that the batch closes the last drawing before anything can happen.  I tried changing some things around but I was unable to get it to work.  I believe that if I create a reactor in the first drawing (the calling session) and have that reactor check for that drawing to become active then check the counter I may be able to get it to work without the Batchworx.dwg.  Currently the Batchworx.dwg is the trigger that runs the cleanup then closes.
Not really sure that anyone is following this but if I get something to work I will post it here.
TimSpangler
  • CAD Naked!!
Re: BatchWORX
« Reply #4 on: May 01, 2012, 08:37:35 AM »
Has anyone had any issues/ comments. I am working on this a bit more and am open to comments to make it easier to use, etc.
matthewj
  • Vanilla
Re: BatchWORX
« Reply #5 on: May 07, 2012, 10:32:30 PM »
Just a thought, could you put the countdown variable into the blackboard namespace?
TimSpangler
  • CAD Naked!!
Re: BatchWORX
« Reply #6 on: May 08, 2012, 07:37:19 AM »
It is not the countdown that is the problem as much as it is the execution of cleanup code after the fact.  Once the drawings have been processed you are returned to the original drawing that launched the Batchworx program.  It has already done its job.  I need a way to now tell the launching drawing that the process has completed and now it is time to execute some cleanup code.  This is the reason for the Batchworx.dwg.  It is used to launch cleanup code.  It is possible with a reactor but I am trying to stay clear of reactor is I can as that would add a level of complexity to the code.  I also do not want to launch cleanup code on a .dwg that is being processed.  I don't want to risk an error during the cleanup and have that effect a dwg that is being batched.
I do believe that a reactor is going to be the best solution. (lips only).
matthewj
  • Vanilla
Re: BatchWORX
« Reply #7 on: May 08, 2012, 08:12:49 AM »
Sorry, it was late, and I wasn't as clear as I could have been.  A reactor is where I was going with that.  I'm not familiar with your code, but this is how I saw it in my head:  When each batchworx drawing is done processing, it decrements the counter in the blackboard. When the counter reaches one, a reactor that checks the counter each time the active drawing is switched fires off the cleanup function and deletes the blackboard variable.
There is a little bit of overhead, but its not much, and writing the reactor code would be a drop in the bucket -- something like this?  (untested)
(vlr-docmanager-reactor nil '((:vlr-documentBecameCurrent . batchworx_check_counter)))
(defun batchworx_check_counter( / )
    (if (= (vl-bb-ref 'batch_counter) 1) (progn (batchworx_cleanup)(vl-bb-set 'batch_counter nil))
PS, I really liked the routine, it was helpful when I was populating my 3d fastener library.  So thanks for that.
TimSpangler
  • CAD Naked!!
Re: BatchWORX
« Reply #8 on: May 08, 2012, 08:21:37 AM »
That's what I was thinking, but I am using the reg to store the counter instead of the BB. Still using the document reactor.
I haven't had much a chance this week to work on it but I hope to get back to it later in the week.
How did it work?  Was the program flow good? Was it intuitive?  Any issues with how it preformed?
matthewj
  • Vanilla
Re: BatchWORX
« Reply #9 on: May 08, 2012, 09:24:27 AM »
It worked really well.  The resulting files were great.
I did run into one issue, after processing about 10 - 20 drawings multiple sessions of autocad would start opening.  The other sessions would open about 3 to 7 drawings each.  I've posted the .batch routine I used.  I'm not sure if it was because I didn't uncomment the clean up program section...  that was a bit unclear in the documentation.
;; Add the start up
(defun S::STARTUP (/)
;;; ------------ ECHO TO THE COMMAND LINE
(princ "\n Begining Batch Process \n")
;; <LOAD DEPENDENT LISPS HERE>
;; <ADD CONTENT HERE>
(vl-cmdf "union" "all" "")
(vl-cmdf "-view" "o" "front")
(vl-cmdf "zoom" "extents")
(vl-cmdf "zoom" "scale" "0.9x")
;; Save the file - if needed
(vl-cmdf "QSAVE")
;; Set the clean up program (remove semi-colons)
;;(if  (= (vl-registry-read BatchMasterKey "Clean") "nil")
;; (vl-registry-write BatchMasterKey "Clean" "<FILENAME>")
;; Close the drawing
(vl-cmdf "CLOSE")
)s
TimSpangler
  • CAD Naked!!
Re: BatchWORX
« Reply #10 on: May 08, 2012, 09:27:16 AM »
What version of AutoCAD?
matthewj
  • Vanilla
Re: BatchWORX
« Reply #11 on: May 08, 2012, 10:48:01 AM »
2012 Mechanical, run as vanilla though.
I recreated what I was doing, batch processing 100 files in one directory.
When the batch process was running, I went about trying to do other stuff on my computer while the processing was going on.  I found very quickly that wouldn't work.  I also found that Autocad spawned about 28 more instances, each with 1 file open.  These 28 files were not processed.
I re-ran the batch process while doing nothing else on my computer (2 times), this time only one extra autocad process was spawned, and it opened 8 (9 in the third test) of the files.  Those eight files were not processed.
TimSpangler
  • CAD Naked!!
Re: BatchWORX
« Reply #12 on: May 08, 2012, 10:52:20 AM »
I think I have a fix for that.  I will post it if you want to try it?
matthewj
  • Vanilla
Re: BatchWORX
« Reply #13 on: May 08, 2012, 11:00:44 AM »
Absolutely, this has been the easiest to use batch solution I've seen so far.  Easy enough for my non-lispy co-workers to use.
TimSpangler
  • CAD Naked!!
Re: BatchWORX
« Reply #14 on: May 08, 2012, 11:32:20 AM »
Try this one and see if this prevents multiple sessions.
roy_043
  • BricsCAD 18
Re: BatchWORX
« Reply #15 on: May 08, 2012, 03:04:13 PM »
Tim,
I was trying out your code in Bricscad. Had do some obvious tweaks of course, but then ran into similar problems as matthewj. The comments below are therefore based on limited tests and I was not using your latest code.
1.
You should consider this scenario: The user selects some drawings for processing and then decides to switch to a different folder. But instead of selecting a new folder the user changes his mind and cancels the folder dialog. Your main dialog now reports: "NO DIRECTORY SET", but the left list_box is not cleared. In fact you can still select items from the list resulting in "nilDrawingName.dwg" entries in the right list_box.
2.
The folder dialog you are using has certain limitations. If you start it in a specified folder the browsing is restricted to that folder and its subfolders. You usually don't want that. On the other hand, always having to start browsing from the "My documents" folder is inefficient. Not many companies use this folder or even the C: drive for their project folders. A solution can be to add a main-project-folder option to your config settings. If such a folder is set the folder dialog can start from that folder saving the user 4-5 clicks every time he uses the program.
3.
The right list_box is sorted alphabetically the left list_box is not.
4.
It would be nice if the dwgs that have already been selected are marked in the left list_box. For example by adding some spaces before the item string.
5.
Since the dwgs in the right list_box can come from different folders it makes sense to display the full path for each dwg. That would perhaps mean having to do away with the symmetry of the dialog.
6.
"Select all" and "Clear all" buttons would be nice.
7.
The bottom button row of your main dialog now has this order:
"Process" "Cancel" "About" *space* "Config"
I would use this order:
"About" "Config" *space* "Process" "Cancel"
That order is more in keeping with the general '"flow" of the dialog.
8.
The separators in your dialogs sometimes have -2 as their background color. I think this should always be -15.
9.
You use a lot of text_part tiles instead of normal text tiles. I don't understand why.
HTH.
Roy.
matthewj
  • Vanilla
Re: BatchWORX
« Reply #16 on: May 08, 2012, 06:08:31 PM »
I'll try this out at work tomorrow.
TimSpangler
  • CAD Naked!!
Re: BatchWORX
« Reply #17 on: May 09, 2012, 07:34:32 AM »
@ Roy,
Thanks for the feedback.  I will look over the list today and see what changes can be implemented.
matthewj
  • Vanilla
Re: BatchWORX
« Reply #18 on: May 10, 2012, 01:10:47 PM »
No-go friend.  Everything works well until I hit the process button;  the dialogue closes and nothing happens.  I checked the config locations, and they are the same as in v4.
Edit: I wasn't completely accurate when I said nothing happened.  The routine turned all of the automatic batch running, it just didn't open any of the files I'd specified.  I had to open the Batchworx.dwg to turn off the batch processing.
« Last Edit: May 10, 2012, 01:25:55 PM by matthewj »
TimSpangler
  • CAD Naked!!
Re: BatchWORX
« Reply #19 on: May 11, 2012, 09:22:27 AM »
How about this?
roy_043
  • BricsCAD 18
Re: BatchWORX
« Reply #20 on: May 17, 2012, 05:51:04 PM »
Tim, I have just tried out the latest version of your lisp (from post #19).
Here are some additional comments:
10. (The numbering continues where my previous post has left off)
The "spawning" of multiple CAD sessions now only occurs if there are multiple sessions open when the Batch command is started.
11.
If a single session is active when the routine is run, the program works OK. But for every drawing that is opened by the process I have to click the OK button in a "Processing in progress... Please be patient" alert dialog. So the process can't be left unattended. This maybe a Bricscad thing though.
12.
Another scenario to consider: The batch process fails for whatever reason. The user gets called away, forgets what he has been doing, and start a CAD session by double clicking on a dwg file. This dwg will now be processed by the batch routine, saved and closed. And if the process runs successfully the user cannot open any other dwg to continue working, because that dwg would also be processed. Using a script to open the drawings and start the .batch file would be safer. In Bricscad this is also faster and there are no alert dialogs. But I know your goal is not to use scripts.
13.
And another scenario: The user selects the calling dwg for processing...
14.
Your Batchworx.docx is not entirely clear about the use of the Batch subfolder. After reading the text I put both .batch file examples in that folder and one of them (Batchworx.lsp) was then erased by your program.
Again, HTH.
Roy.
TimSpangler
  • CAD Naked!!
Re: BatchWORX
« Reply #21 on: May 18, 2012, 08:50:50 AM »
Tim,
1.
I found this issue an I think that I have fixed it to retain the current directory is the user cancels.
2.
There is not much out there for directory selection unless you roll your own.  Unfortunately this is what we have to work with.
3.
Fixed
4.
I am looking at the code, I am thinking of removing the drawings from the list as they are added to the batch list, and vice-versa.
5.
How about adding a description tile below to show the full path of a selected file?  If I enable the full path in the listbox the listboxes could get very wide.
6.
Good Idea
7.
How so?
8.
Good catch, fixed.  That's what I get for coping code from other applications.
9.
I have found that text_part is a bit more flexible during design.  It allows text to be moved around <tabbed> by adding other parts to it.  also there are no margins on text_parts so it seems easier to control the space around them.
HTH.
Roy.
roy_043
  • BricsCAD 18
Re: BatchWORX
« Reply #22 on: May 21, 2012, 05:35:42 AM »
5.
That is a good alternative. Most companies would use some unique project number as part of the dwg name anyway.
7.
How so?
See below.
9.
Bricscad does not correctly display these texts with "\t". One of my tweaks was to replace "\t" with "    ".
What do I mean by "flow" of the dialog?
If I look at the top three elements of your main dialog, I notice that "the main action" is focussed on the right side of the elements. That is where the "Browse" buttons and the list of drawings selected for processing are. In the bottom button row this is reversed. Here the buttons that will be used most frequently are on the left.
A couple of days ago I landed on the msdn website. And after a few clicks I found this text:
All things being equal, users first look in the upper left corner of a window, scan across the page, and end their scan in the lower right corner. They tend to ignore the lower left corner.
I don't know if there is any science behind that quote. The statement may well only apply to people with a language that is read from left to right, drive on the right side of the road and are right handed. Who knows? Maybe it all just depends on what you are accustomed to.
Roy.
roy_043
  • BricsCAD 18
Re: BatchWORX
« Reply #23 on: May 21, 2012, 05:44:09 AM »
Oops forgot this one:
15.
When reading the first line of your .batch files I would use this code to strip off unwanted characters:
(vl-string-trim ";| \t" str)
TimSpangler
  • CAD Naked!!
Re: BatchWORX
« Reply #24 on: May 24, 2012, 02:48:14 PM »
Still looking into this.. I have to grab ALL open session then alert the user is there are more than 1
11.
This is because of the .batch file.  Look in there and remove the alert (or comment it out).  It was only for demo purposes
12.
Have you had this happen.  If the batchworx fails then AutoCAD should crash.  Thus a new drawing would open resetting batchworx.
13.
I have added a check for this once the "process" button is selected, however it is only if it is called in that dwg.  I'll have to spend some more time with that.
14.
ODD it should only delete file with a .batch ext.  I will try to clear up the documentation a bit.  Essentially there are 2 location (a network) (a user) both can have .batch files or you can just use 1 location (if you are standalone)
Again, HTH.
Roy.
Here is a revised .lsp and .dcl.  I removed the /t characters.  I appreciate your time testing this, it will only make it better.
TIM
TimSpangler
  • CAD Naked!!
Re: BatchWORX
« Reply #25 on: May 30, 2012, 07:46:41 AM »
@ matthewj
Did you get this to work with the new changes?
roy_043
  • BricsCAD 18
Re: BatchWORX
« Reply #26 on: May 31, 2012, 03:31:21 AM »
Upon further testing, this time with the Windows Task Manager open, I find that the lisp program will ALWAYS spawn multiple CAD sessions in Bricscad. My conclusion is therefore that this approach to batch processing will not work for Bricscad.
In Bricscad there are two ways to run a batch process:
A.
You can use a script. This will also work in Autocad.
B.
You can use a SINGLE lisp program to handle the entire process.
In Bricscad you can:
- Start a lisp program in drawing A.
- Open drawing B.
- Perform various tasks in dwg B: execute lisp code, call commands (they will run in dwg B) etc.
- Save and close dwg B.
- Open drawing C.
- ... etc.
This is, apparently, not possible in Autocad.
Some comments (old and new):
4.
T:
R:
The vice-versa part has not yet been implemented.
5.
T:
R:
R:
Very nice work on that one. You are even handling multiple selections!
16.
You use acet-* functions without checking if they can be used. Not everybody wil have the Express Tools installed.
17.
Your dcl somewhere has:
alignment = "left";This should be:
alignment = left;But this line can also be removed.
18.
The arrow buttons between the list_boxes are left aligned.
TimSpangler
  • CAD Naked!!
Re: BatchWORX
« Reply #27 on: May 31, 2012, 01:03:00 PM »
I am looking into this a bit more, I can't seem to capture the current session and keep the dwgs in it.
A.
B.
- Open drawing B.
- Open drawing C.
- ... etc.
Nope, other wise this would be a lot easier  :roll:
4.
T:
R:
Yes it has, however if you try to "unload" dwg's from the right side and they are not from the "current" directory they just get dumped, not added back to the left (they don't belong there)
5.
T:
R:
R:
16.
I noticed this yesterday when I was going through the code, this was from my StdLib which does the checking, I'll be adding the check to this also.
17.
Fixed
18.
Yeah, I haven't cleaned up the dialog code yet.  I will add this to the todo list.
roy_043
  • BricsCAD 18
Re: BatchWORX
« Reply #28 on: June 01, 2012, 04:40:06 AM »
4.
T:
R:
The vice-versa has not yet been implemented.
T:
Yes it has, however if you try to "unload" dwg's from the right side and they are not from the "current" directory they just get dumped, not added back to the left (they don't belong there).
R:
The code is there but to get it to work 2 lines have to be changed (you are not adding "\\"):
Line 432:
(if (equal (strcat (vl-filename-directory SelDwg) "\\") BatchDirectory)Line 464:
(if (equal (strcat (vl-filename-directory DwgName) "\\") BatchDirectory)
TimSpangler
  • CAD Naked!!
Re: BatchWORX
« Reply #29 on: June 05, 2012, 08:22:57 AM »
4.
T:
R:
T:
R:
Line 432:
Well when I tested it originally it worked fine, but I was testing dwg's from directly within a directory, not in folders so mine worked fine.  When I tested dwg's within folders mine failed and your solution worked, but your solution didn't work for dwg's in a directory.  The fix:
(if (equal (vl-filename-directory SelDwg) (vl-filename-directory BatchDirectory))
and
(if (equal  (vl-filename-directory DwgName) (vl-filename-directory BatchDirectory))
All seems to work now.
roy_043
  • BricsCAD 18
Re: BatchWORX
« Reply #30 on: June 05, 2012, 01:47:57 PM »
During further testing (see comment 19 below) I have found that an old issue is not entirely resolved:
1.
T:
I found this issue and I think that I have fixed it to retain the current directory is the user cancels.
R:
If the user cancels the folder dialog the BatchDirectory variable is set to "nil" (string). If the user subsequently uses the arrow keys the results are not as expected.
19.
I could not reproduce what you describe in your last post, but your solution points to a new issue. Apparently the variable BatchDirectory can sometimes contain a string that does not end in a path separator. I think it is essential for your program that this variable is either nil or contains a path string that does end in a path separator.
roy_043
  • BricsCAD 18
Re: BatchWORX
« Reply #31 on: June 06, 2012, 03:59:25 AM »
This post in the ODCL forum may be of interest:
http://www.opendcl.com/forum/index.php?topic=1809.0
Here (vla-sendcommand) is used to handle the batch process.
rayakmal
Re: BatchWORX
« Reply #32 on: June 21, 2019, 06:10:03 AM »
The program is very useful for me. My question is how should I modify the code so every time I choose the batch folder, it will directly shows D:\Project\2019\ ?
I tried to change the DCL but it won't work as intended.
  1.         (if (= nil BatchDirectory)
  2.                 (set_tile "files_dir" "D:\Project\2019\")
  3.                 (set_tile "files_dir" BatchDirectory)
  4.         )
  5.
Any help is greatly appreciated.
Re: BatchWORX
« Reply #33 on: June 21, 2019, 08:02:36 AM »
The backslash is an escape character in AutoLISP, therefore to yield a literal backslash in a string you'll need to prefix the backslash with another backslash to mark it as a literal, i.e.:
  1. "D:\\Project\\2019\\"
rayakmal
Re: BatchWORX
« Reply #34 on: June 21, 2019, 10:52:26 AM »
I did, but the browse folder still by default shows the user's folder.
