Author Topic: REvit MEP Ducting Centre lines  (Read 770 times)
diarmuid
« on: March 07, 2012, 04:35:23 am »
Hi Guys,
REvit MEP
Is there a way to show centre lines of ducting without making the surfaces transparent.  When i make the sufaces transparent so that i can see the centrelines i can also see the information below the ducting that used to be "hidden".
Regards
Diarmuid
If you want to win something run the 100m, if you want to experience something run a marathon
RobDraw
Re: REvit MEP Ducting Centre lines
« Reply #1 on: March 07, 2012, 07:17:38 am »
Is this in a plan view?
Rob "The Cleaner" aka "The Creator of Sheets"
Senior Mechanical Designer
Building Systems
diarmuid
« Reply #2 on: March 07, 2012, 09:57:48 am »
yes it is
RobDraw
« Reply #3 on: March 07, 2012, 10:24:43 am »
I tried looking for a way to do it but couldn't find one.
Building Systems
diarmuid
« Reply #4 on: March 08, 2012, 04:03:13 am »
no bother.  I'll keep at it. if i mange to do i'll post it up here on tha aul itraweb thingy
M@yhem
  • Pain is temporary. Quitting is forever.
« Reply #5 on: March 08, 2012, 08:04:08 am »
Hi Guys,
REvit MEP
Nope.
Andy Hudson
« Reply #6 on: April 20, 2012, 04:22:44 am »
There is now :-)
Revit 2013 now has the option to show center lines in circular ductwork. woo hoo.
Just a pity none of the design teams we work with are using 2013 :-(
Revit MEP 2012, AutoCAD MEP 2012, AutoCAD 2011, 2010, 2009
M@yhem
RobDraw
Building Systems
StykFacE
