Author Topic: Read and Write PIA Files  (Read 6632 times)
kaefer
« on: April 19, 2012, 08:00:47 AM »
The same procedure as every couple of years : After IT migrated to new servers, all PC3-saved printer paths are invalid. Either that or there are other reasons to read and write the special format in which AutoCAD's plotter support files are saved.
First, here's a short description of the PIA (whatever that may stand for) file format.
Secondly, since Zlib streams aren't part of the runtime, I needed to download the dotnetzip library, in order to reference zlib-v1.9\Ionic.Zlib.dll.
Code - F#: [Select]
  1. type System.IO.Stream with
  2.     member me.WriteString (s : string) =
  3.         let buf = s.ToCharArray() |> Array.map byte
  4.         me.Write(buf, 0, buf.Length)
  5.
  6. module Zlib =
  7.     open System.IO
  8.     open Ionic.Zlib
  9.
  10.     let read fileName =
  11.         use fs = File.Open(fileName, FileMode.Open, FileAccess.Read)
  12.         fs.Seek(60L, SeekOrigin.Begin) |> ignore
  13.         use zs = new ZlibStream(fs, CompressionMode.Decompress)
  14.         use sr = new StreamReader(zs)
  15.         let s = sr.ReadToEnd()
  16.         sr.Close()
  17.         s
  18.
  19.     let write fileName s =
  20.         use fs = File.Open(fileName, FileMode.Create, FileAccess.ReadWrite)
  21.         use zs =
  22.             new ZlibStream(
  23.                 fs, CompressionMode.Compress,
  24.                 CompressionLevel.BestCompression, false )
  25.         fs.WriteString(
  26.             "PIAFILEVERSION_2.0,CTBVER1,compress\r\npmzlibcodec" +
  27.             "\255\255\255\255\255\255\255\000\255\255\255\000" )
  28.         zs.WriteString s
  29.         zs.Close()
The read function will give you a string which is, to quote, "more or less 'human readable'".
exmachina
Re: Read and Write PIA Files
« Reply #1 on: April 21, 2012, 05:33:18 PM »
About "here's" (http://www.noliturbare.com/more/faq#Q1):
is a good starting point, but contains several errors/lack of information
The header size is 60 No 59
bytes 49->52 = ZlibCodec.Adler32
bytes 53->56 = compressed stream size
bytes 57->60 = decompressed stream size
Look @ this:
http://www.theswamp.org/index.php?topic=37625.0
« Last Edit: April 21, 2012, 05:50:36 PM by whoknows »
