Command: +ribbonEnter <menugroup name>.<element id> of the tab to make active (e.g. ACAD.ID_TabHome):
You can access the Ribbon Tabs by typing +RIBBON on the commandline.I assume you can do that too in Lisp.Code: [Select]Command: +ribbonEnter <menugroup name>.<element id> of the tab to make active (e.g. ACAD.ID_TabHome):
