I didn't realize that I needed to Throw the applicable Exception; I thought that is one of the inherent benefits of using Try... If I must still plan to Throw a particular Exception, the what benefit does Try provide?
** Edit - clearly I have more reading to do on the matter. I'm sure it would help if I went through one of the tutorials too. LoL
You use Try when there is a chance that the code that you place in
the Try block will cause an exception that you want to catch. If you
don't catch the exception, it should be caught by AutoCAD's runtime
but perhaps there's something wrong there.
The confusion about using Throw is that you are writing a method
that is called from LISP, so if the arguments passed from the calling
LISP code are wrong, then you can throw an exception, and the
AutoCAD runtime will catch it, and translate it to a LISP error along
with the error message.
Your mistake in that code, is that you are checking arguments passed
from the calling LISP code, and if they're not what you expect, you are
showing a message on the console and returning null, rather than
throwing an exception that triggers a LISP error, which is what should
happen if the arguments are not correct.
That has nothing to do with using Try/Catch to catch an exception that
might be raised by the .NET APIs that you call.
You really don't need to catch argument-related exceptions thrown
by the .NET code you call, you should just let then bubble up and
stop your code. But if there's a fatal error happening, then you only
need to catch System.Exception, and see what the message is. You
can also re-throw the exception back to the calling LISP code as well.
Catching System.Exception is the 'catch-all' case that will catch any
exception, since all exceptions are derived from System.Exception.
E.g., catch( System.Exception ) is like using vl-catch-all-apply, as they
both catch any exception/error thrown.
