Author Topic: LDD3  (Read 5189 times)
rugaroo
  • The Other CAD Guy
LDD3
« on: December 10, 2003, 12:59:58 PM »
This is a weird question...but it is very important. When you double click on a dwg file, is there a way to make sure that LDD3 opens with the correct profile and what not? I tried changing the open options to have the profile path, but no go, any ideas?
Rug
LDD06-09 | C3D 04-19 | Infraworks 360 | VS2012-VS2017
Dent Cermak
LDD3
« Reply #1 on: December 10, 2003, 01:36:56 PM »
Are you using a custom .dwt file? That's how I make sure. Set everything in the dwt file and then use that template to start all new drawings. To me that is much easier than fooling with the profile, and it does tha same thing.
LDD3
« Reply #2 on: December 10, 2003, 01:39:26 PM »
What I do is copy the shortcuts for both map and LD4 to my "sendto" folder, then right click on the file and select the one you want from "sendto". As far as I know there is know way of doing what you want because the .dwg extension is associated with the the ACAD.exe, not an .arg file. So it depends on the last one you had open (map ldd).
MSTG007
LDD3
« Reply #3 on: June 22, 2004, 10:47:53 AM »
try to export your user profile out to a file. and then in your short cut add the following which references your exported user profile... when double click on shortcut, user profile appears
"C:\Program Files\Land Desktop 3\acad.exe" /p "C:\Land Projects 3\AUTOCAD XXX.ARG" /nologo
Civil3D 2020
